A newbie neds help with some LEDs and HIDs.
    A few necessary lights on my car are not working, Such as a blinker and brake light. I would like to replace them, but I think now is a good time to replace them all with LEDs. What are the first things I, a car newbie, do to get my car lite up?
    Remove your old bulbs then buy some LED bulbs and replace them.
      ^^^There you go. Done deal^^^
        If you want a full LED setup, it's going to cost some money. I had mine all on LEDs, but I took them out because I had 2 people hit my car and the body shops keep replacing them with bulbs (even though I told them to replace with LEDs and where to get them). The only thing I left alone were the reverse lights (which were bulbs to begin with) as they're brighter.
        Keep in mind, with all LEDs, you lighting will appear to stay on (corners mostly) because they require less power to light, and because of that, your indicators will hyperflash (as in when a bulb goes out). This can be remedied by placing an additional load on the circuit (resistors I believe). Search for it as there's a few threads about this.
          http://www.cb7tuner.com/vbb/showthread.php?t=108559
          go here tells you how to install them and also how to get rid of the hyper blink ^this man was talking bout
