Originally posted by mcdizzle
View Post
Lets talk spring rates
Originally posted by 93F22A6 View PostIf your trying to get the perfect 50/50 weight distribution uh yes it does. Scaling the car tells you how much weight is on each tire.
isnt this what corner balancing is for? also that is kinda why i ran lower rates in the rear of my car.
My Members Ride Thread
Originally posted by deevergoteYou have to think outside the box to get IN the box!
Originally posted by mcdizzle View Postoooh ok, now i see what your saying. i thought you were refering to just getting an overall weight of the car.
86 4Runner - 22RE 5spd, 4" Lift, 35x12.5R15 BFG Km2's, 4.10 gears
"The Turtle"
DD/Trail Rig/Mud Bug
i cant describe it, but i think this website does a good job
http://www.nsxprime.com/FAQ/Performa...nerbalance.htm
Originally posted by mcdizzle View Posti cant describe it, but i think this website does a good job
"The Turtle"
The idea with higher rear spring rates is to get the rear more skiddish. Skiddish tails yield yaw change, and yaw change is welcomed in any auto-x.
There aren't too many people that would recommend stiffer fronts than rears when autocrossing. Stiffer fronts will almost always lead to understeer, and understeer has no business on the auto-x circuit.
There are CRX guys that run 600+/900+. G-man's numbers don't seem unrealistic to me.
Originally posted by TheNextEpisode View PostThe idea with higher rear spring rates is to get the rear more skiddish. Skiddish tails yield yaw change, and yaw change is welcomed in any auto-x.
There are CRX guys that run 600+/900+. G-man's numbers don't seem unrealistic to me.Gary A.K.A. Carter
[sig killed by photobucket]
So my guess is that your car will be a dedicated auto-x car and no longer a DD?
I'm currently running Megan Racing coilovers with 14kg/mm up front and custom 8kg/mm rear as opposed to 6kg/mm..I believe that translates to 780lbs/in up front and 450lbs/in rear? Anyways, along with that I also have Progress RSB, rear X-brace, and front 3-point brace, matched with stock DX front sway bar (24mm is it? or 25mm?) Camber is -3.0 up front, -1.0 rear..
Cornering wise, it's great, no doubt about it..In all honesty, I haven't experienced understeer in the past 3 years I think, ever since I upgraded the suspension, added RSB and ran my current camber setup....During hard cornering (low to mid speed) I can definitely feel the rear tires losing traction during exit to keep up with the fronts...Oh for tire pressure, in summer time I usually run 40psi up front and 34psi rear..
However, when it comes to stability under high speed, as well as high speed braking, I find the rear to be somewhat unstable..When I first installed the coilovers, out of 32 dials (32 being the stiffest), I set the front at 26 and the rear at 20...Needless to say, my rear-end would literally float on the highway, so much that it scared the poop out of me...After getting used to it, my final setting came to 28-30 front (depending on wheel/tire combo), and 16 for rear...Even at 16 the rear would still kick out on me...So far I almost died 3 times from my car oversteering during long fast corners...Had I not countersteer I wouldn't be typing this right now lol
But anyways, what I'm trying to say is that, while stiff rear suspension might be good for auto-crossing, you might also want to consider normal road conditions, even more so when it rains...Normal streets aren't exactly all made of slow and tight turns like auto-x courses...To me personally, 8K for rear seems to be plenty stiff..My rear end barely squats, and I can't even set the damper past 16 or I might just die while going 180km/h on the highway I can't imagine what it'd be like if I'm running an even higher spring rate in the rear, let alone stiffer than the fronts!!
Again, just some food for thoughts...But if your car is no longer a DD and simply just a dedicated auto-x car, then forget everything I just said!!
I will be widening my stance by 50mm all around in a few weeks time, as well as replacing all bushings with spherical bearings..I'll also be running -2.5 camber up front and -1.5 rear..After that's done I will be re-tuning the suspension again...I'm hoping that this time I will be able to turn up the rear damper without the fear of losing control...I'm VERY tempted to run 16K up front though
Ronald
neuspeed spring rates (got them from Mr. Nueman himself)
race - 485f 300r
sport - 260f 165r
I am currently using both of these. the race springs up front (485lbs) and then the sport rears (165lbs). I choose comfort lol. I don't do much auto x or anykind of racing in this car just a nice dd. My celica is for that lol. Whitelines FTW.
anyways back to your post. if your getting 600f 800r thats PUSHING LIMITS OF DD. those are close to track only rates. but then your have to consider your ride quality which then you have to look at the shock valving. And if your looking into springs go with hypercoil. my friend have them on his lude.either kill it or drift it...
2002 Toyota Tundra V8
A little more in the back never hurt anyone =D. Get you a nice RSB also that will stiffen the rear for sure and you will have quite a bit of oversteer. Its a nice setup if you understeer. If you go to much it becomes a burden. Those spring rates really dont sound that bad. What are you using for dampening?
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
Originally posted by trah View Postneuspeed spring rates (got them from Mr. Nueman himself)
race - 485f 300r
sport - 260f 165r
Springs, I am going to go with Ground Control coilovers which use stock Eibach race springs
Originally posted by NAiL05 View PostA little more in the back never hurt anyone =D. Get you a nice RSB also that will stiffen the rear for sure and you will have quite a bit of oversteer. Its a nice setup if you understeer. If you go to much it becomes a burden. Those spring rates really dont sound that bad. What are you using for dampening?
Once I get the rates figured out I am going to have a set of Bilsteins custom valved to match the rates.Gary A.K.A. Carter
Originally posted by The G-Man View PostOnce I get the rates figured out I am going to have a set of Bilsteins custom valved to match the rates.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
