Thread Tools Rating: Thread Rating: 6 votes, 4.00 average. Display Modes
Old 02-12-2017, 03:58 PM   #241
excalibur02
Wanna be JDM whore
Looks so smooth!! Damn you and your skills
Instagram username MAURO02
Old 02-12-2017, 09:01 PM   #242
oneoffaccord
thanks maury
Old 02-12-2017, 10:42 PM   #243
Grumpys93
Glad to see your still at it Larry. Progress looks good.
~Nick~
Old 02-13-2017, 05:43 AM   #244
oneoffaccord
same here brother, I'm highly happy with this build this time aroundkj
Old 02-14-2017, 11:58 PM   #245
oneoffaccord
Heres a update:
1) the cabin harness the goes to the computer, under-dash harness, under-hood fusebox and both headlights are out. I am redoing it. Taking both engine harness plugs and rerouting them. So they both can come out where i want them. Same goes for the underhood fuse box, which will be under the dash somewhere lol. I right side where i need it. Just have to lengthen one wire. Next is the left side
2) Since we are slow at work i redid the engine harness at work aswell. Now i just need to plug each plug on the motor and go from there.
3) Mocked up the fuel fittings for the fuel feed line. Ill take these to work and flare the line and that will be done.
4) Test fitting the brake booster/master. Cant wait to paint it and install the lines and fittings.
Old 02-15-2017, 10:06 PM   #246
oneoffaccord
Another slow day at work resulting in some more progress. Cleaned the fuel/brake brackets. Stripped the metal strips that go on to the brackets, going to paint them tomorrow a stain black. Also brought in my fuel feed line and installed the AN fitting for the fuel line.
Old 02-16-2017, 09:06 PM   #247
oneoffaccord
Slow at work resulted in me finishing up these brackets. Its crazy what a few hours of no work can bring
Old 02-16-2017, 11:15 PM   #248
SSMAccord
This looks like great progress. Can't wait to see more.
Curiously, what was the reasoning behind the RSX booster and MC?
Old 02-17-2017, 05:44 AM   #249
oneoffaccord
Both are smaller and look better than the bulky factory one.
Old 02-22-2017, 05:30 AM   #250
oneoffaccord
A little update but not much. I received battery cable thru stud yesterday. Mounted that, added the power wire for the starter. Came out great.. More updates to come.
Old 02-22-2017, 07:38 AM   #251
Jarrett
I have the firewall studs as well, but I don't have cables with those 90-degree boots on them. That makes it look a lot better!
Old 02-22-2017, 06:19 PM   #252
oneoffaccord
thanks man. its those little details that stand out
Old 02-22-2017, 06:38 PM   #253
Rilas
Is the RSX brake booster and clutch master cylinder a bolt on affair? Those look so much better in the engine bay than the stock ones. I know we can do the S2K clutch master cylinder but it requires the spacer. Would be nice not to have to buy 2 pieces to get a better master cylinder.
Old 02-23-2017, 12:30 AM   #254
oneoffaccord
both are a bolt on affair. I ran both the rsx brake master/booster in my brothers 93 se and in my 95 civic coupe. pretty much all Honda ones should fit
Old 02-23-2017, 05:39 PM   #255
SilkyCB
SilkyCB is cool... so far.
So is the only reason for the RSX master/booster for looks?
SilkyCB is offline   Reply With Quote
Old 02-23-2017, 11:38 PM   #256
oneoffaccord
1) its different
2) its more compact
3) it looks better
4) its not old
5) cant think of a 5th answer
Old 02-25-2017, 08:16 AM   #257
oneoffaccord
Well I got my chassis harness all done. Completely eliminated the automatic transmission, cruise control, abs, a/c wiring. Routed the engine wire harness where I wanted it (they all come out together thru the middle of the car). I'm pretty sure I probably missed some wiring for the transmission wiring that goes to the dash but oh well lol. Next is to put the harness in the car and route the engine and headlights where they have to go and its a done deal.
Old 02-25-2017, 03:56 PM   #258
SSMAccord
This looks intense. Keep up the work, sounds like an interesting project.
Old 02-25-2017, 11:23 PM   #259
oneoffaccord
Took the dash out from downstairs. plugged the dash into the fuse box and the chassis harness. Plugged the center and fuel pump harness into the chassis harness. Pretty much made sure everything went were is was suppose to be. I gotta get the chassis harness put into the car next then I can finish up the headlight tuck.
Old 02-25-2017, 11:37 PM   #260
oneoffaccord
