Old 05-13-2018, 12:15 PM   #1
ukemike
CB7tuner Member
ukemike is cool... so far.
Weight of an f22 engine
What does an f22 engine weigh with all but the exhaust on it? I'm going to buy an engine stand for that purpose and need to get the right one without over-spending.
__________________
1991 Accord Lemons Race Car, "The Minnow" RIP
1993 Accord Lemons Race Car, "Green"
Neuspeed Race Springs, Koni Str.t "Orange", Acura CL Rear Sway Bar,
Adj Upper Control Arms -3.0deg front, -2.0 deg rear
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel.
A4 Header, 2" exhaust all the way back, catalyst delete, glasspack muffler, PT12 ECU.
Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
ukemike is offline   Reply With Quote
Old 05-13-2018, 02:31 PM   #2
Jarrett
Contributing Member
For what you're wanting to do, you can get the cheapest engine stand Harbor Freight sells. The engine is in the neighborhood of 400lbs when fully dressed. I think the one with four casters is a little nicer while not being much more expensive.
Either way, Harbor Freight for something like this all day long.
__________________
Old 05-14-2018, 12:47 AM   #3
ukemike
CB7tuner Member
Yup. That's the plan. Just wasn't sure I could get the smallest one. Thanks.
__________________
Old 05-14-2018, 03:33 PM   #4
steelbluesleepR
I shoot people
steelbluesleepR seems to have made some friends!
those things are usually designed for small block chevys and the like, and there's not much lighter than an all-aluminum 4cyl. you're good with just about anything.
__________________
Quote:
Originally Posted by Stephen Fry
steelbluesleepR is offline   Reply With Quote
Old 05-17-2018, 10:17 AM   #5
Size9zombie
CB7tuner Member
Size9zombie is cool... so far.
Quote:
Yep, I have a 350, a 383, and a 2 bolt 400 sbc at home, all on harbor freight stands. They are tough.
Size9zombie is offline   Reply With Quote
