I just came back from the alignment shop and they said I had uneven caster angles in the front end.
This my DD, so suspension is bone stock, brand new UCAs and lower BJs. I had the Alignment done about 3 months ago, so everything is still in spec, Camber is .1* on both sides, Total toe is 5/32"
My LF Caster is 1.8* and my RF is .4*, both positive.
How do I make my RF match the LF? or should it be the other way around?
Right now, my car pulls to the right pretty noticeably. So I'm thinking the right radius rod needs to be adjusted?
Now, to make it match the LF, would I have to add or remove washers from the Pass. Radius Rod?
Alignment sheet attached:
