Brake Setups-->whats the best for us 4th GENer's
This is a sticky topic.
    Thank you cb7 community for all nthe great info.
    Not til pages 4 and 5, has any1 asked about abs setups on 9293.
    I have a 1993 ex with abs, looking to do simple roh with cl hubs rotors, with lifetime warrenty pads.
    Now only but 1 person had a prob with abs.. That's were it scares me, but glory has 5lug..
    Im keepin 4 lug, I don't want to run into any probs with my abs light comin in afterwards.
      Do not worry about your ABS situation. Everything is run off of the axle, and has nothing to do with the calipers/rotors/hubs.
      -Big3racing.net-
      My Build Thread. Many pics.
        Ok thanks.
          bump for info, reread thread, also went to the yard.
          i came across a ka4 legend, on here says legend calipers will work.
          so, the brake idea im thinkin of doing is
          cl hub, ka4 calipers, ka4 bracket, vtec rotor, im asking because i seen that the legend brakes were roh and just made me think.
            Better move the bleeder valve or bleed the calipers while they arent mounted to the car.
              What? Why, wat I listed can I use it?
              Cl hub, ka4 bracket, capiler, rotor
                Im not sure about if all the parts will fit together but
                Legend calipers are tailing edge. meaning they sit twords the rear of the wheel well. The bleeder valve for a caliper is ALWAYS on the top. If you put the legend calipers on your car properly then you cant bleed them. So you either need to bleed them while they are off of the car ( By sticking a block of wood in the caliper and facing the bleeder up ) or flipping the sides ( which for some reason is not reccomended.
                  Something else to add to this thread:
                  Whether you have ABS or not, the non-abs brake master cylinder is smaller in diameter. Pressure = Force/Area, which means that a smaller master cylinder area with a constant applied pedal force will result in higher line pressures. Higher line pressures result in higher clamping forces.
                  Smaller non-abs master cylinder
                  Pros: More line pressure, more clamping force at the caliper
                  Cons: More dangerous for brake lines, more pedal modulation(pedal travel)
                  ABS master cylinder
                  Pros: Less pedal modulation, safer line pressures
                  Cons: Less clamping force at the caliper if applied pedal force is held constant.
                  Now you can see that if you translate this to the other end of the brake system; the caliper: Force = Pressure*Area
                  So a larger line pressure and larger piston surface area will result in higher braking forces.
                  For this reason, you want the largest piston calipers and smallest diameter master cylinder possible AS LONG AS your lines and fittings can handle the pressures.
                  If you were to try to make the ideal system using OEM parts, a non-abs master cylinder with the prelude vtec calipers would be best. The master cylinder is the smallest that bolts up, and the calipers have the most piston surface area, unless the Legend/Vigor ones are even larger...that I'm not sure about.
                    Shit. For now I think ill just stick with just the basic cl hubs rotor and pads, cb oem calipers.
                    Thanks.
                      Thanks.
                      Just get wagon rotors. It will be the same size rotor just a different caliper.
                        Aren't wagon rotors, hor, im tryin 2 do roh.
                        I went to the yard, I did find wagon calipers and bracets, also thought of doin the vigor swap, still hor.
                        I want rotor, for 2 reasons.
                        1 easier 2 change/swap/update rotors from blanks to drilled etc...
                        2 I can always update to 11.1 rotors and vtec calipers.
                        To me its like killin two birds with 1 stone.
                        Update from hor, to roh, then always can update down the line to bigger setup.
                          No sense in upgrading to ROH and not just upgrading the brakes at the same time. Your not going to spend much more money on bigger rotors but if your buying 10 inch rotors and then upgrading to 11 inch your going to spend twice as much.
                          Regardless get the wagon calipers and buy prelude vtec rotors
                            I see what you are saying, just buy the bigger rotors and shit now, rather than buyin 10in then upgrading.
                            So mr tipper, ill shall acquire the following.
                            Cl hubs
                            Wagon brackets
                            Wagon calipers
                            Vtec rotors
                            And pads.
                            Its acutally cheaper to buy either cross drilled/ slotted or both on ebay, I no ebay parts blah blah, but I won't b auto crossin her.
                              Cl hubs
                              Wagon brackets
                              Wagon calipers
                              Vtec rotors
                              And pads.
                              That is correct. Auto-cross or not, cheap rotors can warp easily...even from just hard stops. I have this exact setup. CL hubs, OEM bearings, wagon calipers, brackets, and prelude vtec/wagon rotors...and the rotors are the no-name TAS rotors and I suspect that they are slightly warped. I haven't autocrossed the car, but I have driven it hard and overheated the brakes a few times(pads were smoking). So I would get a quality rotor regardless...especially if you're H-swapped or something of the sort.
                              Also, don't get cross drilled. Get blank or slotted. The pads will overheat before the rotors, so unless you start smoking pads, you don't need a slotted rotor even.
                                Cl hubs
                                Wagon brackets
                                Wagon calipers
                                Vtec rotors
                                And pads.
                                make sure your caliper bracket number and brake rotor thickness are the same number, example 25t wagon brackets need 25mm thick rotors and 23t would need 23mm thick rotors
                                if you do not match these numbers you will have either sponginess or stiff pedal effort
                                my coupe has pretty much the same setup as yours but 93 wagon rotor cause i am still HOR
                                ''COUPE''
                                ''WAGON''
