Well, here i am AGAIN with a different MR thread. Had to pass on keeping the S2000, its ok to DD if you have another beater for winter and can justify insuring two vehicles. I couldnt...so from hunting for an STi and coming up empty handed i stumbled on this "one owner", completely stock 2006 Mitsubishi EVO IX-MR edition w/ 38000 miles.
i wasnt going to have a MR thread, but why the hell not!?
Its not gonna get crazy but ill have some changes/upgrades made.
ENGINE SHTUFF:
RALLI///ART intercooler piping kit
RALLI///ART plug/coil wires
RALLI///ART reservoir socks
ARC super induction box
ARC cooling plate
ARC 1.3 bar radiator cap
SAMCO Sport turbo inlet pipe
COBB Tuning 3'' cat-back exhaust
FUJITSUBO Downpipe
JDM Beatrush underpanel
JDM Beatrush front engine roll stopper
Relocated throttle cable
NEW ENGINE SETUP: need to install still
ETS 2.5" short route UICP
ETS 2.5" LICP
ETS stainless steel upper rad. pipe
ETS 3" bar&plate intercooler (24x11.5")
ETS 3" intake pipe kit
ETS mini battery kit
TOMEI diverter valve (bov)
Braille 11lb mini battery
Sun Auto Hyperforce ignition ampl./stabilizer
Walbro 255 fuel pump
HKS racing SMF filter & MAF adapter
FLUIDS
Mobile 1 10w30 Full Synthetic EP (engine)
Amsoil Severe Gear lube 75w90 gl5 (tcase & rr diff)
Amsoil MTG 75w90 gl4 (trans)
OEM ATF SPIII (ACD unit)
OEM oil filter
OEM ps fluid
EXTERIOR /// INTERIOR:
Perrin 4'' antenna (fits better than the 2ft oem one)
OEM Mitsubishi smoked DOOR VISORS
UKDM Evolution trunk emblem (painted matte black)
UKDM "MR" trunk emblem
EDM rear bumper foglight and trim **waiting for JDM rear bumper**
JDM Evo VII tail lamps
PIAA H11 Plasma Yellow fog light bulbs
ARP rear diffuser *FRP* --SOLD IT!!
OEM "MR" emblem for front grill (modified)
OEM Recaro seats (good enough!!)
Alpine CDA-9886 headunit (ipod ready, woot!)
Alpine typeR components front
Alpine 6&1/2 coaxials rear deck
BLITZ Dual TT
GruppeS 60mm hvac gauge pod panel
AMBER LEDs for gauge cluster
AMBER LEDs for HVAC cntrls
AMBER LEDs for ign key ring/cig. lighter/coin tray
STRI 60mm EGT gauge
STRI 60mm boost gauge
STRI 60mm oil temp gauge
JDM BEATRUSH shifter base bushings
JDM BEATRUSH license plate bracket
SUSPENSION /// CHASSIS:
BILSTEIN HD dampers
SWIFT spec-R MR springs (FR:157-358 RR:153-380)*purchased*
WHITELINE adj. 24mm rear sway bar
JDM BEATRUSH interior floor performance bar
JDM BEATRUSH front lower performance bar (5pt)
JDM BEATRUSH front lower arm support braces
CUSCO rear trunk brace bar
JDM MINES 3pt. front strut bar
BRAKES:
OEM 4 pot BREMBO calipers
MOTUL Dot-4 fluid
HAWK HPS pads (GARBAGE!!!! tossing out!!!)
Stoptech front & rear slotted rotors
Stoptech front & rear stainless steel lines
WHEELS /// TIRES:
OEM *forged* BBS wheels **SOLD**
235/45R17 BFG KDWs (not too bad for street tires)
Enkei RPF1 17''x9.5'' +38 (silver)
Ichiba 20mm wheel spacers (w/extended studs)
Ichiba 15mm spacers (for rear)
Enkei NT03+M 18"x9.5 +27 (powdercoated matte black)
KICS project 10mm spacers (front)
Muteki *red* closed end lugs
Dunlop Direzza 255/35R18 tires
FUTURE PLANS:
UKDM FQ360 front CF lip (by RALLIART)
ARC front wing lip spoilers
Beatrush propeller shaft mount bushings
Beatrush rear diff spacers
Beatrush exhaust mani heat shield
CUSCO adj. front sway bar bracket
JDM MINES o2 housing
Ralliart hood-vent panel
Ralliart ACD controller
Satisfied GranSport GS5 pads
SS clutchline
Tomei duracon shift knob (short)
CBRD BBK full turbo
Whiteline roll center correction kit
TUNE
Some other little stuff...... :P
more pics to come....
ENGINE SHTUFF:
ARC cooling plate
FUJITSUBO Downpipe
ETS 2.5" LICP
FLUIDS
OEM oil filter
OEM ps fluid
BLITZ Dual TT
STRI 60mm EGT gauge
BILSTEIN HD dampers
BRAKES:
MOTUL Dot-4 fluid
WHEELS /// TIRES:
FUTURE PLANS:
SS clutchline
CBRD BBK full turbo
TUNE
