Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Naturally Aspirated
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 09-11-2012, 06:15 PM   #1
Joey GT-R
Super Moderator
Joey GT-R has a HUGE cock! Joey GT-R has a HUGE cock! Joey GT-R has a HUGE cock! Joey GT-R has a HUGE cock!
Send a message via AIM to Joey GT-R Send a message via MSN to Joey GT-R Send a message via Yahoo to Joey GT-R
Most Powerful Naturally Aspirated CB7 List
Rules & Regulations
Your Car Must be a CB (90-93 Accord)
Your car must be running
You must be an active member
You must post a Dyno Sheet
_________________________________________________
Required Spec Sheet
If any parts are stock just omit the entry.
If you have a Port & Polish or any extensive Block Machining please include the relevant info.
Engine/Frank:
Intake:
Header(Include any modification):
Exhaust:
Cam/Gear:
Valvetrain:
Pistons(Bore and C/R):
Rods:
Crank:
Tuning Software:
Octane:
1/4 and/or 1/8th Time if possible.
Dyno Sheet and Numbers (Resize Accordingly):
If you have a MR/Build Thread please include that in your post so that others can go back and look at your work and accomplishments.
'94 JDM H22A: 178whp 146wtq
Originally Posted by deevergote
Joey GT-R is offline   Reply With Quote
Old 09-11-2012, 06:18 PM   #2
Joey GT-R
Super Moderator
King of the N/A CB7s
#1 jdm92_accorn - 249whp 194wtq - F22A/F23A (E85)
#2 gainesvilleCB7 - 242whp 166tq - H22A
#3 jchsmiley - 238whp 192wtq - H22A
#4 Bravo-man - 237whp 187wtq - H22A
#5 GunRunner - 234whp 185tq - H22A1
#6 91H22ACB7 - 204whp 169wtq - H22A
#7 GhettoCB7 - 202whp 154wtq - H22A
#8 Mike1357 - 200whp 161wtq - H22A
#9 jdm_inspired - 195whp 164wtq - H22A
#10 Sequence - 193whp 134wtq - H22A
#11 Losiracer2 - 191whp 147wtq - H22A
#12 pupildel - 186whp 158wtq - H22A
#13 Restless - 177whp 138wtq - H22A1
#14 PhatAccord - 175whp 152wtq - H22A
#15 90CB7EURO - 172whp 151wtq - H22A1
Old 09-11-2012, 06:26 PM   #3
Joey GT-R
Super Moderator
Archived Builds
NWaccord - 231whp 180wtq - H22A - 7/21/13
Joey GT-R - 178whp 146wtq - H22A
Old 09-11-2012, 06:29 PM   #4
Joey GT-R
Super Moderator
Contenders
19dabeast85 - 134whp 126wtq - F22A1
thumping_accord - 153whp 146wtq - H23A1
F22Turbo702 - 154whp 150wtq - F22A6
zmos86 - 171whp 131wtq - F20B/F22A
cb9love - 171whp 151wtq - H22A4
Old 09-11-2012, 08:26 PM   #5
Joey GT-R
Super Moderator
This thread is for strictly posting your setups and brief discussion of those setups listed. I don't want a million posts saying "If I install Part A & Part B how much power will I make?". Posts not adhering to these rules will be deleted. Bashing(not to include constructive criticism, there is a difference) of other people's setups will be addressed accordingly.
Old 09-16-2012, 09:09 PM   #6
jchsmiley
Accord of the Month: March 2013
jchsmiley is cool... so far.
I guess I'll go ahead and post my setup.
This is only a baseline and the first tune with this build. I will be expecting bigger numbers once I actually get a header and a free flowing exhaust. This was using stock JDM H22 header, with stock cat, and 2.36" RSR catback.
Engine specs:
Jdm H22A
Skunk2 Pro1 Series Cams
S2 Pro Series valvesprings
S2 adjustable cam gears
S2 titanium spring base & retainers
ARP Studs
Comnetic .051" HG
H23 manual tensioner conversion
EuroR IM (portmatched)
Omni 69mm TB (portmatched)
Rosko Racing fuel Rail
410cc RDX injectors
Exedy Stage 1 clutch
Competition Clutch Ultra-lightweight flywheel
Hondata IM gasket
jchsmiley is offline   Reply With Quote
Old 09-17-2012, 01:47 AM   #7
Joey GT-R
Super Moderator
Congratulations, it appears we have our first King! What kind of compression ratio did you get with the Cometic? I really look forward to the addition to your chosen header and full tuning session. I'm sure it will pay off and put you past the 200whp milestone.
Now....who will be the first to unseat him? Who dares?
Old 09-17-2012, 02:18 AM   #8
domesticated
domesticated seems to have made some friends!
Would like to throw mine on. Honestly I'm a bit disappointed. I have fewer mods than he and I was expecting more out of the engine. In the spring I'm going with some big cams and other goodies, well see what happens. I'll be up on this board in a few months.
'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing - Chassis Dynamics Data
domesticated is offline   Reply With Quote
Old 09-19-2012, 07:44 PM   #9
Ghetto_CB7
Ghetto_CB7 is cool... so far.
Engine: F22a1 (211000 Miles)
Modifications:
Bolt Ons:
-----Ebay Short Ram Intake
Internals:
-----Stock
Exhaust:
-----Stock F22a1 Downpipe
-----Stock F22a1 Exhaust manifold
-----2.25" Catback Exhaust
-----Stock Cat
-----Magnaflow muffler
Computer:
-----Pt3-A01 stock obviously (also 5 speed vehicle)
Dyno
__________________________________________________ __________________
Engine: H22a from HMO
Modifications:
Bolt Ons:
Internals:
-----Stock
Exhaust:
-----Stock JDM H22a Downpipe
-----Stock JDM H22a Exhaust manifold
-----Stock Cat
Computer:
-----P13-A01
Miscellaneous:
-----H23 Auto to Manual tensioner conversion
Dyno
Modifications:
Internals:
-----Stock
Intake:
-----Euro R Intake Manifold (Modified by Rosko Racing)
-----Acura RDX 410cc fuel injectors
-----PBT 74mm to 68mm Throttle Body
Exhaust:
-----Stock JDM H22a Downpipe to 2.5" collector modification
-----3" Kteller mandrel bent Catback Exhaust
-----3" Carsound Cat
-----3" X 18" resonator
-----3" Magnaflow baffled (Not straight through) muffler
Computer:
-----p28 Chipped and tuned on neptune
Miscellaneous:
Modifications:
Internals:
-----Stock
Intake:
Exhaust:
-----Bisimoto H22 Header
Computer:
Miscellaneous:
The lower value graph is one from without the header, and the higher one is after tuning with the bisi.
201 whp and 153 wtq
All h22 dyno were done on 93 octane, but I ran the same tune on 91 with no modifications and no det.
Also all dyno's were taken on the same dyno
Ghetto_CB7 is offline   Reply With Quote
Old 09-19-2012, 07:47 PM   #10
19dabeast85
19dabeast85 is cool... so far.
This is a relatively stock unimpressive f22 but with bolt on mods many new members ask questions about so here goes:
Block:..........Untouched F22a1. 265k+ miles. 160-165psi static compression.
Head:..........F22a6 Camshaft
Intake:........H23 runners, plenum, TB. Functional IAB's @ 4.3krpm. Air boost, FITV, and EGR blocked off.
Air Filter:.....True 3" CAI with Apexi Power cone. Reflective wrap on pipe in engine bay.
Header:.......Bisimoto with 2.5" flange.
Exhaust:......Magnaflow 2.5" seemless highflow CAT. 2.25" mandrel exhaust. 20" & 14" 2.5" Magnaflow resonators. 2.25" Deltaflow 60 muffler.
Tune:..........P06 tuned on Dynojet with Crome.
Dyno sheet(NOT a 2jz as dyno sheet is labeled lol), (133whp, 126wtq):
My Member's Ride Thread
19dabeast85 is offline   Reply With Quote
Old 09-20-2012, 01:41 AM   #11
dj_ender
Mod\Dubstep Pusher
I call bullshit on Ghetto CB7, your car doesn't run that anymore...
Old 09-20-2012, 01:50 AM   #12
Ghetto_CB7
Rules state that car must be running, it says nothing about still making the same power.
For those that don't know I over revved a downshift on a mountain run a few months back and bent some valves.
Needless to say she is injured and current compression numbers are 90, 140, 150, 180
Now delete this and ban djender for not following the rules
Old 09-20-2012, 01:53 AM   #13
dj_ender
Mod\Dubstep Pusher
It also says you have to be an active member. Your last post was 6 months ago, not very active IMO.
Old 09-20-2012, 02:00 AM   #14
Ghetto_CB7
my last post was 9 minutes ago
Old 09-20-2012, 02:39 AM   #15
PhatAccord
PhatAccord is cool... so far.
Send a message via AIM to PhatAccord
92 lx sedan
94 jdm h22a
double stacked plenum spacer
bb4 aem cai w/ bypass valve
70mm omni power tb
port matched plenum
blox fuel pressure regulator
dc header
2.25" in. piping w/ resonator
cb7 oem cat.
2006 civic si muffler
balancer belt delete
act 6 puck unsprung clutch
act lightened flywheel
ur crank pulley
tuned on p28 hondata s200
4700 vtec engagement
stock internals
91 octane
PhatAccord is offline   Reply With Quote
Old 09-20-2012, 02:40 AM   #16
mndude07
mndude07 seems to have made some friends!
Send a message via AIM to mndude07
This is a stupid argument. Obviously Ghetto_CB7 is capable of making an engine with said power output. Shit happens. I say it's fair to be on the list. If you call b.s., then give him the money and watch him do it again.
There are no black and white suspension answers!!!!!!!!!!!
mndude07 is offline   Reply With Quote
Old 09-20-2012, 12:22 PM   #17
Joey GT-R
Super Moderator
I personally invited Ghetto_CB7 to post his dyno on the thread. While it's unfortunate that his car is currently not capable of replicating that power, I understand the situation.
However, you do have a point that you must be an active member. I'm assuming that his recent inactivity coincides with the misfortune of his car? I'll allow it for this special case, since I know him to usually be a solid contributor to the site. However if he goes M.I.A. again, he will be removed.
Old 09-20-2012, 12:51 PM   #18
Joey GT-R
Super Moderator
For the record all decimals .5 and up will be rounded up. Any decimals .4 and below will be rounded down.
I just want to give everyone my appreciation for posting up. This is all nicely coming together. I believe this will benefit not only the forum but the "future" generations as well as they start to assemble their own personal builds.
Old 09-20-2012, 01:32 PM   #19
Macaqueistrong
Boats 'N Hoes
Macaqueistrong is cool... so far.
I beleive NWaccord would be the top dog with his SE coupe.
http://www.cb7tuner.com/vbb/showpost...&postcount=115
He also holds the title for Most Powerful Forced Induction CB7!
http://www.cb7tuner.com/vbb/showpost...14&postcount=1
Macaqueistrong is offline   Reply With Quote
Old 09-20-2012, 03:04 PM   #20
Joey GT-R
Super Moderator
I'm well aware...but he has to post it himself.
