Old 12-31-2013, 03:54 PM   #1
PR CB7
PR CB7 is cool... so far.
Send a message via MSN to PR CB7
PS pump interchange
Will the p11 & poa intechange?
The head is F22B dohc with a p14/H23 bracket I have a p11 pump on there right now, but so far the only pump that I know fits it the bb4/p11, the cd5/poa looks like it will fit
Thanks guys
Just do what PR CB7 said.
PR CB7 is offline   Reply With Quote
Old 12-31-2013, 06:00 PM   #2
Granite CB7
Granite CB7 is very helpful Granite CB7 is very helpful
I'm going to say no. The hardline sections of the high pressure line at the pump are way different for starters. If that's not a big deal to you (not sure what chassis you're working on) the tensioner setup + hardware is very different too. The P11 pump can be found on all 92-96 Preludes S, Si and VTEC. What's the issue that you have?
Granite CB7 is offline   Reply With Quote
Old 12-31-2013, 10:33 PM   #3
PR CB7
Pump is whining, and trying to get one cheap/jy its not easy
The car is a cb, it used to have h22, but still has the prelude line
Old 01-01-2014, 12:30 AM   #4
Granite CB7
Gotcha, since you've got a line made up specific to the P11 pump only I guess you'll have to stick with it. Of the replaceable internal parts on both pumps, it seems that most of the parts are the same and are of the same construction. Probably not worth hybridizing though since a few are different.
