Remove my P/S belt and...
    I'm going to the raceway tonight and I thought that if I remove my P/S belt I could do better time (my best time is 16.9 :\ ) So I remove It and got a test run....
    The engine rev 'faster' but FU%& it's really hard to drive.... I have to use my 2 hand to turn the wheel and it's very hard to turn at a light when i'm stop :\
    Maybe it's cause i have 16" but tomorrow i'm gonna put my belt back :P
    yep thats normal without powersteering, honestly i've owned more cars without p/s and im used to it so I just cut my belt off of mine
    Originally posted by jboyce
    i f'd this girl last night i hadnt seen in a while...used to be cute, but when i had her naked lying on my bed i noticed she had gained alot of weight and looked like a manatee rolling around on my bed.
      Yuppppppppppppppppppppp!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
      That is how it is..... This why people ask for power steering....
        with the lines running thru the pump, turning the wheel forces fluid thru the internals of the pump... it gets much easier if you bypass it, next time you remove the belt you can connect the upper pressure hose directly into the feed hose at the bottom/front of the pump and hold it with a band clamp. easily reinstallable that way too.
