Go Back   CB7Tuner Forums > Site Features > DIYs > Engine DIYs
Old 03-28-2013, 10:21 AM   #21
Bad_dude
Bad_dude seems to have made some friends! Bad_dude seems to have made some friends!
Question
Hey Ryan,
I went to the junkyard and took the pressure relief valve off and there's only a spring that came out. The valve does not come off does it?
Also the plate on mine, directly behind the valve and behind that of the high pressure hose connection on the pump is crack and I think that is what causing the little leak. If I replace that plate, item #7 on the diagram, it might stop the leak. My question is if I take that plate off will the valve shoot out from the spring being in the front of that portion?
Either that or my leak is coming from seal #20 and not the shaft seal.
Thanks.
Bad_dude is offline   Reply With Quote
Old 03-29-2013, 01:32 PM   #22
RyanD
RyanD seems to have made some friends! RyanD seems to have made some friends!
Send a message via AIM to RyanD Send a message via Yahoo to RyanD Send a message via Skype™ to RyanD
Originally Posted by Bad_dude View Post
Hey Ryan,
Thanks.
iif the plate is cracked then that would cause a leak. i would take off both plates to replace the one to not risk the valve shooting out.
ithe valve is in there its just really far in the tube
visit vgruk
RyanD is offline   Reply With Quote
Old 04-01-2013, 10:08 PM   #23
RyanD
just updated the thread with pics of the pressure valve. enjoy and i hope it helps!
visit vgruk
Old 04-03-2013, 12:12 PM   #24
Bad_dude
Question
Thanks bud. Does the valve just sit floating inside the chamber or do you have to unbolt it? What part of the valve do you blow out? That little hole in the middle?
Every fixed your problem after rebuilt?
Thanks.
Old 04-03-2013, 12:45 PM   #25
RyanD
Thanks.
Yes it floats. Blow out the top and the little hole. My pump ran dry for to long. I had to get a new one that I'm fixing to rebuild
visit vgruk
Old 04-03-2013, 10:51 PM   #26
Bad_dude
Question
Do I spray the valve with some brake cleaner then blow it out or leave the oil on there then blow?
Thanks.
Old 04-04-2013, 07:35 AM   #27
RyanD
Thanks.
Either or
visit vgruk
Old 04-10-2013, 08:11 AM   #28
s2cmpugh
s2cmpugh is cool... so far.
Thanks for the DIY, it really helped when I replaced my seals yesterday. I do have a question though; after I tightened everything back together, I had use a wrench to rotate the pump as I couldn't do it by hand anymore. Did this happen to you?
Thanks!
s2cmpugh is offline   Reply With Quote
Old 04-10-2013, 10:52 AM   #29
RyanD
Thanks!
It did and to this day I could never figure out why. It seems normal.
Glad the day helped!
visit vgruk
Old 04-10-2013, 02:36 PM   #30
s2cmpugh
Thank you sir! My only guess is that the new seal around the shaft produces a very tight fit and might add some friction until things get spinning fast again.
Old 08-18-2013, 03:08 PM   #31
Mishakol129
Mishakol129 may have said something they shouldn't have...
So what does reverse thread mean, that I have to turn it to the right to loosen it instead of the left?
Just ordered the kit from Rock, gonna consult the Honda manual as well as this. Thanks for the info!
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
Mishakol129 is offline   Reply With Quote
Old 09-15-2014, 10:30 PM   #32
RyanD
just a quick little update since i last did the rebuild. pump still runs like its brand new. now my rack leaks damn salty old bitch
visit vgruk
Old 09-15-2014, 10:38 PM   #33
wildBill83
wildBill83 seems to have made some friends!
Yup, my rack developed a leak this last winter... It's on the list for the SE rebuild coming up this winter.
So when are you doing a rack rebuild thread RyanD?
wildBill83 is offline   Reply With Quote
Old 09-15-2014, 10:46 PM   #34
RyanD
sure why not ill take a crack at it.
visit vgruk
Old 09-16-2014, 04:46 AM   #35
H311RA151N
Silver Member
I remember this! We took this thing apart and put it back on probably 15 times. Good times, good times...
Any little piece if debris will clog that pressure relief right up. Then push the shaft seal out as soon as it builds pressure. I cannot count how many times I watched that thing piss it's self seconds after putting it back on.
I don't think I will ever forget how to rebuild one though.
Find me on YouTube
https://www.youtube.com/channel/UCx7...BeHuX87LzYChKA
Old 09-16-2014, 07:53 PM   #36
RyanD
LMAO! i think i went through like 4 bottles of PSF those 2 days. man that sucked.
i remember now.your house is cursed. it took me an hour when i first did it. then i come to your place and it takes 2 days!
visit vgruk
Old 09-16-2014, 08:16 PM   #37
H311RA151N
Silver Member
Yeah at like what $7.50 a bottle? And it was cold as fuck. Luckily now my shit's insulated and heated. You moved back home just in time to miss out on the good shit. Things were just starting to get real when you left.
Do a rack rebuild though man seriously. I'm going to puss out and get one from Detroit Axle. He went up in prices though and he keeps steadily climbing... He's at $140 shipped currently up from $120 shipped 6 months ago.
Find me on YouTube
Old 06-01-2020, 11:18 PM   #38
ca93accord
ca93accord is cool... so far.
RyanD,
i know this post was back in 2013 but i was wondering if you are able to post those pictures again. You probably do not have them. If someone asked me to re-post pictures that i posted a few years ago, i probably would have a hard time finding those pictures. that is ok if you don't have those pictures, i just had to try and ask. i am in the process of rebuilding my power steering pump. I will try to make a video or take pictures to share as i carefully take apart the pump.
ca93accord is offline   Reply With Quote
Old 06-02-2020, 06:01 AM   #39
H311RA151N
Silver Member
Originally Posted by ca93accord View Post
RyanD,
Ryan doesn't get on here much anymore but I'll let him know.
Find me on YouTube
Old 06-02-2020, 08:35 PM   #40
fleetw00d
This exploded view can help to show where things go:
90 LX 4dr 5 spd 385,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 192,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
