Go Back   CB7Tuner Forums > Parts & Performance > Audio/Electronics
Old 02-13-2018, 01:35 AM   #1
chi
CB7tuner Member
chi is cool... so far.
Sunroof problems
Cant get the sunroof in my 92 to close. When i got the car the guy said it wouldn't close,and if it would close it would just open to vent mode and stay there. Fuse is good,idk about the motor for the sunroof itself though,what all do i have to check and what all should i check? Switch lights up so i know it has power going to it.
__________________
Follow me on IG to see my builds/pics
dmfb919
chi is offline   Reply With Quote
Old 02-13-2018, 05:35 PM   #2
rustyaccord
CB7tuner Member
rustyaccord is cool... so far.
If you pop off that circular cover in your headliner, there is a manual override for the sunroof. You will need the crank for it though. It should be included in with your tire iron. I can't remember off the top of my head but I think it's a hex drive so you may be able to use an allen wrench to crank it closed.
__________________
rustyaccord is offline   Reply With Quote
Old 02-13-2018, 07:27 PM   #3
fleetw00d
Contributing Member
It is a hex drive, so an appropriate sized allen wrench will do the trick. Does the motor work at all?
__________________
90 LX 4dr 5 spd 376,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 254,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 171,151 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=205114 RIP
92 EX coupe auto 190,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
07 Element EX AWD 175,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 02-13-2018, 08:45 PM   #4
chi
CB7tuner Member
Im not sure if the motor is good or not,it might be the switch. Everything got drenched in the 2-3yrs before i bought it. I didnt think to check that out though,atleast itd be closed and i can take my plastic wrap off lol
__________________
dmfb919
Old 02-13-2018, 09:38 PM   #5
fleetw00d
Contributing Member
I was just wondering if it didn't work at all or if it just budged a little like it was jammed. You have a wiring diagram?
Old 02-14-2018, 03:13 PM   #6
chi
CB7tuner Member
It doesnt move at all. The switch lit up when i had the battery in the car but it still didnt move. I don't think i have a diagram for it,actually i dont think i have any diagrams lol
__________________
dmfb919
Old 02-14-2018, 03:15 PM   #7
Rilas
Gold Member
You can manually close it with a 5 or 6mm hex. I just replaced the entire glass portion of the sunroof, and I fully removed the entire frame from the car to do so. Even if the wiring is shot, you can open and close manually just like they mentioned above. My car has no power and I've opened and closed it a few times to test and check on things.
__________________
Old 02-14-2018, 08:17 PM   #8
fleetw00d
Contributing Member
Quote:
Man, you must like wrenching! The glass can be replaced from the top.
Old 02-15-2018, 10:07 AM   #9
Rilas
Gold Member
I didn't know you could replace it from the top until after it was already done. Besides this allowed me to re-glue on the seals that had almost all come off. I did have a side goal to dropping the sunroof frame though. I was going to see if I could fix any of the roof that was dented from the inside. Turns out it wasn't possible, so I kinda wasted time.
I'm curious to see though if fixing all of the seals will cut down on some wind noise inside the cabin.
__________________
Old 02-15-2018, 12:18 PM   #10
fleetw00d
Contributing Member
I practiced on a sedan in a JY before I eventually found an intact glass panel for my coupe.
Old 02-16-2018, 06:30 PM   #11
chi
CB7tuner Member
It wont close all the way,gets maybe an inch from closing then wants to slide back
__________________
dmfb919
Old 02-16-2018, 07:27 PM   #12
fleetw00d
Contributing Member
Quote:
With the motor or the crank?
Old 02-17-2018, 08:04 PM   #13
chi
CB7tuner Member
The crank
__________________
dmfb919
Old 02-18-2018, 06:47 PM   #14
fleetw00d
Contributing Member
Looks like you may need to at least drop the headliner to troubleshoot further.
Old 02-18-2018, 07:03 PM   #15
chi
CB7tuner Member
I think I'm just gonna replace the motor and switch,if that doesnt work I'll just take it all the way out and put a piece of plexiglass in place of it
__________________
dmfb919
Old 02-18-2018, 09:19 PM   #16
fleetw00d
Contributing Member
You can get a whole new assembly (used) for $50, seems a shame to just stick plexiglass in when you'd have to take the whole assembly out anyway.
Old 03-08-2018, 06:02 AM   #17
chi
CB7tuner Member
I think i need new tracks on it,there's a ton of slop in the sunroof,i almost got it closed the other day,itll get like 1/2in from closed then slide back. That was with a 5mm hex key,the switch has power until you press a button
__________________
dmfb919
Old 03-08-2018, 10:40 AM   #18
Rilas
Gold Member
On all 3 of the sunroof frames I have taken out now, all the of the nuts holding the tracks in the rear were loose. I can see this causing you some issues with it closing. Also the gear gets a ton of worn out rubber packed into it. If you remove the frame you can undo the bolts that hold in the "screws" that move the window frame back and forth. Once this pops off a ton of packed in rubber should fall out. Sorry I can't describe this better.
__________________
Old 04-25-2018, 05:21 PM   #19
chi
CB7tuner Member
Is there a writeup on what i need to do to get my sunroof and frame out or is it pretty straight forward? I'm gonna give it a shot when i get home,i just wanted to check with someone that has knowledge on it before i break mine lol
__________________
dmfb919
Old 04-25-2018, 05:25 PM   #20
Rilas
Gold Member
Just be very careful taking the headliner out of the car. I broke the tabs off on the rear that support it to the roof. I ended up using Gorilla Glue Epoxy to reattach them and haven't had an issue. Just something to be aware of. Otherwise to remove the sunroof it's just an electrical plug and 10x 6mm bolts.
__________________
