Go Back   CB7Tuner Forums > Parts & Performance > Suspension
Old 02-11-2018, 12:14 AM   #1
Bunta
CB7tuner Member
Bunta is cool... so far.
Bilstein doesn't make dampers for CB7's?
I'm rather confused by something I noticed on Bilstein's own website. I was looking for information on their HD series dampers in order to remove some concern that the "B6" dampers were or were not the same as the HD's and I have been unable to see dampers for our car listed. I checked under their listing for "MK4 coupe" with production year of like 89'-93' and they have "none listed".
I believe BilsteinUS site gave me the same result, none available for the CB7 (on that site I only had the option of choosing the 4-door sedan EX for our generation). Initially I was just trying to confirm that the "B6" dampers were the same as the "HD" dampers but now I'm wondering if they have stopped producing or offering anything for us.
I know the Ground Control/ Koni yellow combo is tried and true but from what I have read the HD's are a bit better quality( although they don't have a knob to fiddle with which isn't a big deal to me) which is why I'm trying to figure this out. Anyone have any input on this conundrum?
Bunta is offline   Reply With Quote
Old 02-11-2018, 10:00 AM   #2
wtfisafleek
CB7tuner Member
I'm not sure where you're seeing these HD struts but the only ones I see online from Bilstein are the B6s. You can just compare part numbers and that would eliminate weather or not they're the same.
Old 02-11-2018, 12:31 PM   #3
Rilas
Gold Member
If your talking about the B8's then you have to order them from over seas. They are not available in the US.
__________________
Old 02-11-2018, 03:38 PM   #4
Bunta
CB7tuner Member
Quote:
No I was actually just looking around for the Bilstein "HD's" which are listed on the drop spring/damper/coilover thread.
Old 02-11-2018, 04:00 PM   #5
fleetw00d
Contributing Member
I know they have the B6 available, I have a full set on my 90 and on the front of my 93 wagon.
__________________
90 LX 4dr 5 spd 369,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 250,000 MRT: http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 168,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=205114
92 EX coupe auto 190,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 02-11-2018, 04:54 PM   #6
Bunta
CB7tuner Member
Quote:
what do you have them paired with on your 90'?
Old 02-11-2018, 05:19 PM   #7
fleetw00d
Contributing Member
Quote:
I have stock springs at all four corners. EX sway bars front and rear.
Edit: TireRack shows them for all four corners - $111 each.
Old 03-06-2018, 02:20 PM   #8
gloryaccordy
Contributing Member
gloryaccordy seems to have made some friends!
You want Koni Yellows anyway
__________________
Quote:
Originally Posted by lordoja View Post
gloryaccordy is offline   Reply With Quote
Old 03-08-2018, 12:02 PM   #9
HenRoc
Black Thunder
HenRoc seems to have made some friends! HenRoc seems to have made some friends!
Send a message via AIM to HenRoc
I have a full set of B6s that were installed by the previous owner of my wagon. I don't know if I'd want to lower it using those though..I already have a set of Koni Yellows waiting to be put on but they need a refresh first.
__________________
Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
HenRoc is offline   Reply With Quote
Old 03-08-2018, 12:07 PM   #10
Rilas
Gold Member
I absolutely love the ride of my coupe on the HD B6's for the CD wagon.
Although to truly make them work well I paired them with Nuespeed Race springs and FFC/Cheddas Auto extended top hats. I had to do both the front and the rear, but the ride is so incredible now.
Throwing these by themselves on a set of lowering springs will leave you disappointed.
__________________
Old 03-08-2018, 12:35 PM   #11
Bunta
CB7tuner Member
My original plan wasn't to use "lowering springs" but HyperCo springs in custom rates. I was only looking for about an inch and a half drop if anything when I was looking at the Yellows/HD's. I have since changed my plans and am going a different route.
Old 03-08-2018, 12:41 PM   #12
Bunta
CB7tuner Member
Quote:
not that it's of any consequence now but why would I want the Koni yellows over the other Bilstein options? I'm not in particular NEED of being able to adjust the damping force but if I want/need to I'd like to have an adjuster that works for it's full range of adjustments.
Old 03-08-2018, 02:40 PM   #13
HenRoc
Black Thunder
Howd you elimate that sag in the rear? I ordered a set of custom made rings for the Koni yellows to elimate that booty sag. And with the help of Dave aka CyborgGT I'm waiting on a set of cast iron locating arms for my car so I can finally finish up my prothane kit.
My plan is to make the suspension as tight and responsive and probably use my old Neuspeed tower bar and a generic rear tower bar until I get a full set from ESP.
I can already tell the difference on the OEM rubber bushings vs the prothane kit I had on my old sedan, with the prothane it was darty not bouncy everytime I hit a bump with the current OE bushings you can definitely tell its very jarring and soft.
__________________
Henry R
Koni/Neuspeed
Old 03-08-2018, 06:21 PM   #14
Rilas
Gold Member
Henry, I'm not sure what booty sag you are referring to? With all my suspension setup's I haven't had the rear end "sag" or sit lower than the front. Granted on the setup's I've had, the Nuespeed Race springs have been in all of them.
Also even with a entire car sitting on the Prothane / Energy Suspension bushings I don't find the car "darty" but it is very precise. In fact it makes my '04 TL feel sloppy, which it isn't.
__________________
Old 03-08-2018, 08:30 PM   #15
HenRoc
Black Thunder
Ive seen it on some wagons where the rear end of the car seems to sit lower than the front maybe its just me that notices that I have a set of sport springs never went for the race ones though.
__________________
Henry R
Koni/Neuspeed
