intake manifold
    intake manifold
    maybe a stupid question but would an h23 intake manifold make a difference on the f series ?
    Yes and especial if you have a a1 it flows more air.
    STANCE|WORKS
      This! Here is a diy for you. It's not a hard swap.
      http://www.cb7tuner.com/vbb/showthre...&highlight=h23
      Originally posted by Dr. Shuffles
      Prius? Fuck that shit. I can't afford those things. Why do you think I'm driving a Honda that's old enough to buy beer?
        i have an A6
          Originally posted by camachoooooo View Post
          i have an A6
          It's a upgrade on any f. That a1 just lacks some parts the other motors do.
            On an a6, keep your runners, and use the plenum and throttle body from the H23. Much easier to do, a larger charge of air off the line, better airflow through the power band and there is only a slight difference between the two lower halves, one will produce a tiny bit more high end power, the other will produce a tiny bit more torque.
              sorry if im thread jacking... but i have an H22A intake mani sitting on my back porch... will it or at least the plenum fit on an F22A1? for some reason i think the answer is no but i figured id ask.
              90 LX 5spd 2dr (2011-2014)
              93 EX 5spd 2dr (2013-2015)
              92 LX 5spd 2dr (2015-present)
                No it will not fit on your A1, you could use the plenum and throttle body if you had a6 or h23 runners though.
