What do blown shocks sound like?
    I'm pretty sure I have at least one blown shock, but I'd like some definite confirmation before I start replacing them.
    • When I do the push up and down test, the results seem normal.
    • When I hit large bumps at speed (like uneven road getting on a highway) it seems like my car shifts horizontally along the road.
    • I just replaced my sway bar and a lower control arm. They were cracked where they connect along the link
    • When I turn left at speed, I hear a rattling. When I go back straight, it stops.
    • I see no worn components. The ball joints have no play, and the tie rods seem firm.
    I can get Quick Struts for about $140 a side. Autozone is offering a 15% off deal until midnight tonight, so I'm going to be doing some last minute inspections on my car tonight to see if I can justify pulling the trigger.
    MRT
    sneaky motherfucker
    is there any fluid on strut? if it seems stiffer then usual when you push down on it it is blown for sure
    " Insert funny quote here "
      Is the noise a rattling or a click? may be the axles boots are busted and the bearings are going out.
      Procrastination is a THIEF of time!!
      MY MRT
      http://www.cb7tuner.com/vbb/showthread.php?t=203992
      My First CB7
      http://www.cardomain.com/ride/705233/1990-honda-accord/
        I'll have to take a look. I have a feeling it might've been blown for a while, and is just now making the noise. If that's the case, then any sign of fluid is probably gone.
        How do you define stiffer than usual?
        It's defintely a rattling. I've replaced both axles before, and I know what they sound like when they go bad. Same for the bearings. Defintely not a noise indicative of either of those.
        MRT
        sneaky motherfucker
