Go Back   CB7Tuner Forums > 4th Gen-eral > Other Automotive > Other Automotive Members Rides
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 08-14-2017, 01:53 PM   #321
H311RA151N
This thing sits and has sat for a few months. I may have to use this to pull my Talon. The oil gets diluted in this thing super quick (rich fuel mixture) so I figured I would do an oil change.
Oriellys stinks so the only oil filter they had was a Wix XP. I'm not running synthetic (anymore) because I think the 460 has an internal issue. At the very least a bad distributor gear or a really sloppy timing chain. Either way I'm going to run it (if I move which I think I'm going to).
I went with cheap oil. And... an expensive oil filter. But it'll do.
Once I move, if I move the truck will be parked again, until I can pull the engine out. All it has to do is make it. (And pull my talon on a trailer).
Every time I log in there are hardly any new posts. Several days can go by and there's only a couple pages worth at best of new posts. This place is seriously dwindling. Sad.
Old 08-15-2017, 12:14 AM   #322
Crankshaft
Crankshaft is cool... so far.
Too bad you do not live closer to me as i have a connect on cheap(i mean cheap) syn blend oil for $20 a case. We run almost 500 miles a week so i started using that, only issue is that he only has 10w30 but last time i checked he had 1k plus cases. Filters i use either Hastings or private label wix from Rockauto, by the way thanks again for the coupon.
Old 08-15-2017, 02:33 AM   #323
H311RA151N
I would sure take you up on it. That's dirt cheap. 500 miles a week is mad. So is 1000 cases of oil! But hey, I can see it with those miles.
No problem on the coupon. Your very welcome friend!
Old 08-22-2017, 04:17 PM   #324
H311RA151N
Changed oil.
Old 08-29-2017, 08:15 PM   #325
foamypirate
Generous Douchebag
foamypirate seems to have made some friends! foamypirate seems to have made some friends!
Glad to see you still have this rig!
I won't/can't rag on your for the Wix/Valvoline combo...tis' what I run on everything, lol!
Originally Posted by sweet91accord View Post
foamypirate is offline   Reply With Quote
Old 08-30-2017, 12:19 AM   #326
H311RA151N
Still have it. Drove it yesterday. I forget how much I like driving it.
Yeah Valvoline is about the best affordable oil in my opinion. And most parts stores have Wix.
Old 10-16-2017, 01:42 AM   #327
H311RA151N
It's under the knife right now. Front end is tore apart. Replacing upper and lower ball joints as well as all bearings and seals in the front end. It's at my fathers shop on the lift. Like old times.
I have a 1300+ mile journey to my new home in Jackson Wyoming the 31st of this month. Lots to do before then.
Taking pics but can't post them yet.
Old 10-22-2017, 04:22 PM   #328
H311RA151N
I have the front end buttoned together. It was a pain but necessary. So glad to have it behind me. All new bearings, seals etc. Also installed what are called "slingers" on the axle stub shafts. Will keep debris from entering the hub through the back of the knuckle. I can't wait to see how it drives.
Only thing I wish I would have known is that grease can freeze. They make whats called freezer grease for extremely cold climates. Until the summer when I can clean all the new Timken and Valvoline marine grease out I'll just leave the hubs locked in. Incase they freeeze.
Waiting on all new Moog problem-solver tie rod ends and and adjusting sleeves. Will install them Monday. This week we're replacing the engine mounts and the driver side floor board.
Will post pics when i get better service. Maybe next week.
Old 10-24-2017, 05:29 PM   #329
H311RA151N
Got the front end completed yesterday. All bearings, ball joints, tie rod ends and tie rod end sleeves.
And I've started on the engine mounts. The passenger side is already removed. Got it out last night. One of the nuts were loose and the mount was really spongy. Removing the driver side tonight it will be harder.
Bought a couple things for Wyoming.
A Kats handi-heat 300 watt magnetic block heater.
A Kats 36" 80 watt battery heater.
And a 2' heavy duty 3 to 1 extension cord with lighted ends to run both into a single outlet.
Old 11-09-2017, 04:39 PM   #330
H311RA151N
This made it much easier. Cutting the nuts off the upper ball joints.
Old 11-09-2017, 05:25 PM   #331
H311RA151N
Replacing the engine mounts.
Rivets holding bracket to frame. Used plasma cutter. Gouging technique. And grinder.
Driver side engine mount issue. Nut broke free to backing plate. Had to remove bracket from block (goes between block and mount) without removing the mount from the bracket. Took some thinking.
The fix for the nuts breaking free from the bracket between the block and the new mount.
Old 11-09-2017, 05:42 PM   #332
H311RA151N
Truck finished.
Camper shell I got.
Kats 80 watt battery heater. New 14x5 air cleaner in the background.
Oil filter, 3 to 1 cold weather outlet with lighted ends, G-Clamp camper shell clamps, battery heater, 300 watt Kats Magnum oil pan heater.
Old 11-14-2017, 02:00 AM   #333
H311RA151N
Pictures from my 1300 mile 25 hour journey. Was a long journey in this. Glad it made it.
Old 11-14-2017, 12:53 PM   #334
Rilas
At least you got a nice journey across our beautiful country! All the elbow grease and hard work that you put into the Ford certainly shows. Made a 1300 mile trip flawlessly, great job man!
Old 11-16-2017, 07:36 PM   #335
foamypirate
Generous Douchebag
Awww, man, I miss those kinds of views. Great work on the truck! That twin beam front suspension is such a weird setup, like half IFS, half solid axle.
Old 12-16-2017, 06:50 PM   #336
H311RA151N
It was quite the experience. Many very neat views along the way. Did this trip again twice this week. Once in the Talon to Missouri and once in the Accord back here. And thanks! It's appreciated for sure.
Appreciated!
It's quite the oddball I think as well. I prefer a solid axle for simplicity but, I didn't engineer the truck. Dana 60 solid axles are a common swap for these. But just the used axle alone typically costs about $1000 or maybe a little more.
