Go Back   CB7Tuner Forums > 4th Gen-eral > Other Automotive > Other Automotive Members Rides
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 09-24-2014, 08:16 PM   #21
wildBill83
wildBill83 seems to have made some friends!
So what are the plans for the engine? Decided yet?
wildBill83 is offline   Reply With Quote
Old 09-24-2014, 08:31 PM   #22
H311RA151N
After I get the front and rear differentials done and all the front end bearings replaced then the engine will get some attention.
In the near future (probably start in about a week and a half) I will do some work to the engine to ensure it runs well through the winter.
-ENGINE-
Carter AFB 9000 Series Rebuild Kit With Brass Floats
Holley Chrome 14" Air Cleaner
Fel Pro Valve Cover Gaskets
Fel Pro Oil Pan Gasket
Gates Water Pump
Fel Pro Water Pump Gasket
SKF Front Crank Seal
Spectra Heater Core
Standard Water Temp Sender
Rotella T6 Synthetic 5w40 Diesel Oil Gallon (2)
Motorcraft Oil Filter
Corteco Power Steering Pump Repair Kit
About $300 worth once again. Not to shabby.
Long term as in the spring I plan on pulling the engine out and rebuilding it. I don't think I'm going to stroke it after all. From some extensive research I have came up with the following.
-BOTTOM END-
Ford Racing High Performance Engine Gasket Sets M-6003-A429
Clevite H-Series Rod Bearings CB818HN STD
Clevite H-Series Main Bearings MS1039H STD
Keith Black KB Performance Piston and Ring Kits KB206KTM-020 .020 Over +15cc
Moroso Truck Oil Pan 8 Quart 20612
Moroso Oil Pump Pickup 24504
Moroso Universal Dipstick Kit 25970
Melling High-Volume Oil Pump M84DHV
Melling Heavy-Duty Intermediate Driveshaft IS-84
Milodon Freeze Plug Kit 34038
-TOP END- (incomplete)
Lunati Voodoo Cam and Lifter Kit Hydraulic Flat Tappet 10340702K
Clevite Camshaft Bearings SH1766S
Weiand Stealth Intake Manifold 8012
ARP Stainless Steel Intake Manifold Bolt Kit ARP 455-2101
http://www.summitracing.com/parts/lun-10340702k
-----------------------------------------In The Tetons----------------------------------------------
Old 09-24-2014, 08:59 PM   #23
wildBill83
She's going to be torquey.
I know someone who isn't getting stuck this winter... and maybe pulling others out of the ditch eh? (damnit I'm already talking like a cannook)
That intake/cam and over bore with new internals is going to make this a fun truck to drive. What are you looking at spending on machine work?
Old 09-24-2014, 09:27 PM   #24
H311RA151N
I hope it's nice and torquey! I am not getting anything as for MPG so it better give me some kind of a trade off!
It should go anywhere this winter. I'm going to take it out and see what it will do, I'll tell you that. I hope I get a good snow storm that'll will show me the limits this winter.
Machine shop work will be kinda extensive.
First thing is having the block sonic tested.
I plan to bore it .030 over.
Valve guides will be machined for the over .550 lift cam. It might not be necessary but I want the added assurance.
The heads I will rework myself. The exhaust ports in D3VE heads have a large hump in them. Just a hillbilly job on the stock heads people have seen gains from 30-50hp. I will do a nice mild job on them myself.
I will likely have the bottom end balanced as well. That isn't real necessary in this case but it can't hurt.
Most people want to rev these things kinda high (6000-6500) but I would rather have brute low end grunt myself. Sometimes revving the crap out of something is fun. But other times boogieing on down the road changing gears below 2000rpm is fun too.
Old 09-24-2014, 09:50 PM   #25
wildBill83
What granny gear is on there? What is your final drive reduction ratio? Shouldn't ever need anything over 4k RPMs on that monster.
I grew up on big trucks (mostly chevy) but I have a good deal of respect for Fords (don't get me started on the newer Dodge).
Personally I always wanted an old 1/2 ton to putz around in and pull tree stumps with. I looked at a few before deciding on my S10 Blazer.
My dog likes the Hondas but he sits in the passenger seat of the S10 Blazer while I work on it and I can just see him anticipating sticking his head out the window in the wind. He misses my old Jeep.
Personally I have a goal to own many vehicles for many different purposes and reasons and this bewilders my woman to no end.
Old 09-24-2014, 10:53 PM   #26
H311RA151N
All the thing did was haul wood for the last owner who bought it in 2008. He put 6000 miles on it in 6 years.
I took it out and got with it pretty good for a while. It started to run a little better.
I don't plan on driving it anymore until I rebuild the transmission, do the diff work, rebuild the transfer case and do some engine work. I don't know how much fluid the diffs, transmission and transfer case have and I don't want to chance it.
Old 09-24-2014, 11:27 PM   #27
H311RA151N
The granny gear is pretty neat actually. This truck has one of the few T19s that got the 6.32:1 first gear.
When I put it in 4 Low and in 1st gear at about 3000rpm you can walk in a somewhat fast pace beside it.
Gears are 3.55 in the back and 3.54 in the front. I got lucky and got the big Sterling 10.25" rear axle.
I found papers today stating that this truck was special ordered along with the original owners manual. According to Carfax I'm the 3rd owner.
I like everything, Chevy's, Dodges, Fords. I don't like the mind set owners of any make have sometimes but I guess that's just how some people are. I'm not brand biased by any means. Ever manufacturer has made cool stuff.
I hear you about your GF or wife or whatever... My GF gets on my case sometimes about my car habits. But she likes it most of the time. She says a car never stays in my possession without seeing major improvement s from how it was when I got it. Anyone who knows me pesters me about buying my stuff because they know how I am.
Old 09-25-2014, 02:01 AM   #28
H311RA151N
I'm looking for another forum to figure some stuff out on my front end and I'm not having any luck. I registered to http://www.ford-trucks.com and I already hate it... It's slow as shit and the info sucks. You go to the '80-'86 forums, click on a sticky and the links are all for other years of trucks.
I'm looking for info on replacing the front wheel bearings, diff seals, u-joints and such but the stupid "How Toos" as they call them are for newer non-lockout hubs. Nothing worse than a jumble of incomplete information that you have to wait a decade for the page to load.
I think we need a branch off of this forum. Let's call it 1FTtuner.com
Old 09-27-2014, 06:44 AM   #29
H311RA151N
Ordered the carburetor rebuild kit. Along with the power steering pump rebuild kit.
http://www.carburetor-parts.com/Cart...Kit_p_730.html
The upgraded front axle universal joints should be here this week. I wanted to go that route so I know I'm not going to lose 4x4 this winter.
http://www.dennysdriveshaft.com/p168...or_ford_w.html
I tested out the 4x4. The transfer case sounds good. I don't think it has been put into 4x4 much during it's life. The front diff was low. I didn't really care for that to much but I don't think any damage has been done.
On another note. I have found out that from '72 - '87 Ford retarded the timing on the 460 by 4* to pass emissions. So there are timing sets refereed to as "straight up" which the timing is set to 0*. So that's a nice bump in HP/TQ along with some MPG.
I think I'm going to go with a Comp Cams Magnum double roller timing gear set. Nothing better than making some HP/TQ/MPG for $65.
http://www.autozone.com/autozone/par...3639_505200_0_
Old 09-27-2014, 05:13 PM   #30
wildBill83
I went with Clevite for my double roller set. Granted it's not a true roller for $40. A tip I learned is to use motor cycle chain lube on the chain and it will reduce noise and wear.
Old 09-29-2014, 04:09 AM   #31
H311RA151N
Really? I might try that out. And Clevite is well known for making good stuff.
I am limited on timing sets as I need a "straight up" set. Kinda crappy. But I'm glad I have the option.
Old 09-29-2014, 04:15 PM   #32
H311RA151N
I received my carb kit today. I think I'm going to be pretty pleased with it. Ordered it on Friday, got it on today. I like that! $50 shipped.
Old 09-30-2014, 09:11 AM   #33
H311RA151N
Old 09-30-2014, 01:52 PM   #34
H311RA151N
Got this today as expected. Always get the right stuff, undamaged, on or before time from these guys. Can't say that about everyone... I couldn't be more pleased.
Corteco (OEM) power steering pump rebuild kit. $22 shipped.
Old 09-30-2014, 02:57 PM   #35
H311RA151N
This thing works great. Not a bad $80 freebe. Came with the truck.
Old 10-01-2014, 04:01 PM   #36
H311RA151N
Upgraded Spicer U-joints from www.DennysDriveshaft.com came in today. One day ahead of schedule.
Old 10-01-2014, 04:31 PM   #37
H311RA151N
I need a new cluster cover. Mines cracked.
Had to remove the bezel as I needed to put it in the bath tub to wash the dust and dirt off of it. Got in cleaned up and ready to go back on.
Also taking this time to replace the wiper switch and headlight switch. I have some lighting issues and the wipers don't work.
Old 10-08-2014, 12:43 PM   #38
H311RA151N
Doin' the carb today. Finally getting started on this thing after gathering enough info and parts to keep rolling with it. Should start making some good progress.
Carter AFB 9755S 750cfm manual choke.
Old 10-09-2014, 01:15 AM   #39
H311RA151N
This carb was most definitely fucked with.... found all kinds of shit missing and tampered with. Had my father come take a look and show me the ropes of carburetion.
- It was dirty as can be.
- Metering rod on one side was missing a spring. One metering rod was also jacked up.
- One side of the pump jet was clogged. It's also called a secondary booster I believe. So that's why it would fall on it's face with a swift jab at the throttle.
- Secondaries were not opening all the way due to a previous person screwing up a linkage.
I will have it back together in the morning after I hunt down some new metering rods and springs.
Old 10-09-2014, 08:08 AM   #40
Accrdwgnguy
Originally Posted by H311RA151N View Post
I don't know much about Fords, but I bet you could get a factory tach from the big trucks to fit that blank spot in the middle. I'm running a factory tach from a C70 in my C10 and it's pretty cool.
