Thread Tools Rating: Thread Rating: 31 votes, 4.97 average. Display Modes
Old 07-11-2015, 12:18 AM   #41
Rilas
Well I didn't do anything on this tonight. But I did manage to make some progress last night.
-Brakes bled
-Misc electrical hooked up
-Cleaned more
Here is the front half of the heat shield after being cleaned. I still have to finish cleaning up the bottom of it but the top is done.
Heat Shield Top
Heat Shield Bottom
Heat Shield Grime
Sorry I didn't have before pictures of the heat shield, it was totally oil soaked for over a foot into it. Hoping over the weekend I can get everything back up under the car, get it put on the ground so the axle nuts can come off. After that I can get the knuckles out and get the ball joints pressed out and new ones in. Once that is completed I can finish reassembly and see if she starts. Slowly making progress.
Rilas is online now   Reply With Quote
Old 07-11-2015, 11:30 PM   #42
Rilas
I didn't manage much in the way of any large projects today. Although I finished up my last bit of cleaning. I can not even tell you guys how tired I am of cleaning various car parts. I spent around 6-7 hours today scrubbing mainly on the under body of the car, trying to get years of oil, dirt and filth off the undercoating.
Heat Shield Bottom Side
Underbody Passenger Side (Notice the oil has discolored the underbody coating after so many years. This is actually clean I promise. Also I know there is one more dirty spot on the left hand side. I will clean this tomorrow.)
Underbody Driver Side (Undercoating is somewhat discolored on this side but not as much.)
Underbody Center
Underbody with Heatshield and Exhaust
Tomorrow I will get the knuckles out of the car, so they can be dropped off on Monday. I don't have a press so I will have to pay a nominal fee to have it done. Should only be $10-15 at the shop my cousin works at. Will also have the upper ball joints pressed out of the upper control arms at the same time. Yesterday after work I also picked up the last 2 cooling hoses I need to finish the cooling system. Ordered a set of ST sway bars yesterday as well. I still plan on picking up a Progress rear sway bar for this coupe and will eventually move the ST to a different sedan I plan to buy after I get my current one sold.
Old 07-12-2015, 11:43 PM   #43
Rilas
Today didn't go nearly as well as I was hoping it would. I finished cleaning up the grime on the bottom of the underbody. All the cooling hoses are now hooked up. More misc electrical taken care of. I only managed to get one knuckle out of the car due to breaking my breaker bar on the axle nut on the drivers side.
Breaker Bar Broken 1
Breaker Bar Broken 2
Passenger Side Upper Control Arm Bad Ball Joint
Passenger Side Lower Bad Ball Joint
So after breaking my breaker bar and not wanting to break a second one. I've decided that I'll just get the passenger side done tomorrow. Get it put back together, then take it to the tire shop and have them break it loose for me. Once it's loose I'll disassemble the drivers side at home get the ball joints pressed out and in. Then I'll get it aligned. I've also ordered an Ultra Racing upper strut bar. I'll post up some pictures once it arrives. As usual there is more that I can't remember from today.
Old 07-13-2015, 08:07 AM   #44
Grumpys93
nice progress, underside looks great by the way. Do you have a lift at home or is that on jackstands?
~Nick~
Old 07-13-2015, 12:15 PM   #45
Rilas
I wish I had a lift at home. Unfortunately it's just on jack stands, and I lay on a creeper a lot.
Old 07-14-2015, 01:36 AM   #46
Rilas
Well after a long weekend I managed to forget my knuckle and upper control arm at home. So these will get dropped off tomorrow. Although I took this time to start putting the interior of the car back together after the wire tuck. I managed to get a few more things done tonight.
-Wiring under dash wrapped and routed
-Wiring all arranged to fit under trim pieces and otherwise hidden
-Vacuumed under carpet and surrounding area on passenger side (under ecu/tcu tray, misc)
-Blower Motor reinstalled
-Ecu and tcu mounted and installed
-Dashboard reinstalled
-Glove compartment reinstalled
-Carpet reinstalled on passenger and driver side
I still have a few misc item around the dashboard to reattach but otherwise it is complete. I still need to get the center console area figured out. A bracket needs to be installed somewhere for the JDM arm rest to screw into. I think it's been awhile since I've looked at it.
So after looking at how much larger the P14 ecu is than the PT6 I sat and pondered for a long time how I was going to make this gigantic P14 sit where the PT6 did and still hook up the ecu connectors. If they are pushed out too far they hit the plastic venting for the rear foot area. I finally decided to cut off 2 of the mounting tabs on the ecu and 1 one the tcu. This allowed me to shift over the tcu giving the ecu plugs enough room. I wasn't sure if this was going to work because the tcu plugs were so close to a mounting tab for the tray. The result was this.
ECU/TCU Mount 1
ECU/TCU Mount 2
ECU/TCU Installed
Dashboard and Glove Box Installed
Thats enough for tonight I think. It was a long day, I had to work at a satellite out of town today. Along with everything else on a Monday, with a sick GF and baby. I'd say I did alright for the night. I just can't believe I'm finally this close to actually having a running car. It's kind of dumb founding I've been waiting for this since I brought it home so many months ago.
Old 07-16-2015, 09:25 AM   #47
Rilas
Last night yielded more progress.
-Interior assembled including JDM center console arm rest
-Inner fenders cleaned up (had a massive amount of oily buildup on the inside )
-Body cleaned behind fenders
-Vacuumed water drainage area (can't believe how much crap was packed up under the wiper motor assembly)
-Fenders installed
-Headlights and side markers installed
My little guy helping me for a little bit right as I got started.
Passenger Fender
Drivers Fender (Bunch of duct tape residue on it from the damaged bumper PO's idea to fix it instead of buying a $4 piece at Honda to fix it right)
Interior Finished (It is still very dirty. At another point I'm going to take all of the interior out and clean it. Meaning all the trim, carpet and seats. Also you might notice that the drivers seat is any tan leather seat from an Accord while the SE coupe's were very different, but the drivers seat was destroyed when I bought it. I put the sedan seat on the coupe rails and swapped the back onto the coupe seat assemblies as well. This allowed me to retain the farther lean forward for passengers to get in the back. The drivers seat was cleaned and conditioned while it was being swapped. If you couldn't tell it looks so much nicer than the passenger seat and is still soft as new.)
I feel like there is finally a light at the end of the tunnel. At least for this stage of this car. I would like to actually get it on the road and enjoy it some before winter arrives again. I still need to buy a battery, I'm not looking forward to that. I think I'm going to go with an Optima of some sort.
Old 07-16-2015, 10:22 AM   #48
Grumpys93
Nice Progress you got there. I see your little man is doing the JDM pose! That sucks about the PO using duct tape, hopefully you can get it all off.
~Nick~
Old 07-16-2015, 10:40 AM   #49
Rilas
Sadly I have to replace that fender. It skimmed something and at the very front of the curve of the wheel well it smoothed out the line in the fender. I will still try to get the residue off, so it doesn't look as bad till the fender gets replaced. My little guy just absolutely loves to be out in the garage, climbing all over the car and playing with my tools. Hopefully a little gear head in the making!
Old 07-16-2015, 11:13 AM   #50
Ralphie
Stalker
Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed. Ralphie is damn fine. Damn fine, indeed.
This thread is exactly what I want to do with an Accord.
I used to own a 93 SE in Geneva Green and I loved that car but I sold it foolishly because the sunroof was leaking(had been replaced once by me) and I did not have the time or money to fix it.
Now I own a house with a complete garage and I have acquired tons of tools but I do not have extra money for a project.
Great thread man!
Good luck on the rest!
She is going to be awesome when she's done!
Ralphie is offline   Reply With Quote
Old 07-16-2015, 07:30 PM   #51
Rilas
Great thread man!
Thank you for the compliments so much Ralphie. I hope that you can find another for yourself soon. It's too bad that you had to pass along the last SE you had. The Geneva Green is such a great color on these cars too.
Old 07-16-2015, 08:00 PM   #52
laz93se
ContributingMember
laz93se is cool... so far.
Great work on this build , your attention to detail is second to none.
laz93se is offline   Reply With Quote
Old 07-17-2015, 10:07 AM   #53
Rilas
Thanks laz93se, I really appreciate the comment.
Old 07-17-2015, 10:30 AM   #54
Rilas
Managed to put in some more work last night. It took several hours of messing with the fenders, headlights and bumper to get them all aligned correctly. I didn't want the gaps looking bad by being large at the top and small at the bottom. So while I didn't get much more done than getting the bumper installed all the body lines look good now.
-Wiring finished
-Fender inner liners installed
-Mud flaps installed
-Grill installed
Front End 1 (Ignore the slight sag under the passenger marking light. The fender bracket isn't installed on that side yet. I need to pickup one of the retaining clips for it from Honda. It lines up very nice when holding it by hand.)
Front End 2
So I'm sure after all the wiring pictures and such, you have all noticed that there are no fog lights even though the harness is installed. Well when I bought the car one of the fog light housings was cracked and leaked water for who knows how many years. This totally rusted out the reflector, so I only have one usable fog right now. I'm trying to figure out if it's worth trying to get it re-chromed or if I should just buy a different one. I'll post of up some pictures of how bad it is today or tomorrow. Also I want to try and find an oem bumper cover first as well, since this is after market is had no markings on the inside for the pattern.
Old 07-17-2015, 12:15 PM   #55
Jarrett
Just buy a new set. Assuming you do get them re-chromed, you'll still have a cracked lens. You can buy a pair without the harness for around $200 and then resell your current pair for $125 or so.
Old 07-17-2015, 12:23 PM   #56
Rilas
The lens isn't cracked. It's the back housing that is cracked and JB Weld would seal it up no problem. But I have been debating just buying a new pair and having some spare parts for them.
Old 07-17-2015, 12:41 PM   #57
Grumpys93
what side fog is it? I will more then likely not being using my fogs on my new intercooler set-up and ill have to look when I get home but one of my fogs is in great condition the other has the back housing messed up as well.
~Nick~
Old 07-17-2015, 12:47 PM   #58
Rilas
I'm not sure off the top of my head. I actually started working on it when I got the car. I'll pull it off the shelf tonight when I get home and see what side it is and let you know.
Old 07-20-2015, 09:38 AM   #59
Rilas
This weekend was very busy but I still managed some progress on Lola.
-Splash guard installed (cleaned also it was filthy on the drivers side)
-Starter installed
-Bypass hose for cooling installed (forgot about it earlier, in place of deleted fit valve)
-Intake tube installed
-Knuckle installed
-Upper control arm installed
-Outer tie rods hooked up to knuckles
-Down pipe installed
-Shifter cable hooked up
-Battery tray installed
-Battery cables hooked up
Engine Bay 1
Engine Bay 2 (I know this isn't the AEM V2 I have listed. But it will not fit with the battery I have right now. I have relocated the battery in my sedan, it will be moved over to Lola in a week or two, after that the V2 gets installed. Soon there will be no battery an AEM V2 and custom brackets to support it.)
Passenger Side Fog Light Reflector 1
Passenger Side Fog Light Reflector 2
Passenger Side Fog Light Housing 1
Passenger Side Fog Light Housing 2
I only have about 12 items left on my punch list to wrap up the car. Then its double check everything and finally try to start her up.
Old 07-21-2015, 07:45 AM   #60
Grumpys93
holy rust batman!
~Nick~
