Old 11-11-2017, 06:27 PM   #1
kratemertyl
kratemertyl is cool... so far.
Main relay good, but no voltage at pump
Ok so heres how it went down. Car was running great. Got crashed on the driver side while sitting in a parking lot. Car started up just fine and i drove it home. Due to the door not functioning i let it sit for a week or two without driving it. Jumped in it to start it anf would not fire.
Noted that i could not hear the fuel pump prime. Checked pressure at fuel rail and saw i had none.
Checked voltage at fuel pump and found none. Check #2 and #28 fuse, both good. I then assumed main relay went out. Bought new one and replaced.
Same result.
Tested old relay, it tests good.
Jumped wires at main relay connector, yellow and blue(always hot) with yellow(power to fuel pump) and fuel pump kicked on.
Using a test light put clip on the ground pin of the connesctor and the probe on the hot wire. Tested good.
When ignition is turned on the connector shows power at the black and yelloe wire.
I think thats everything.
Im wondering if my alarm has shorted out and is not allowing the car the fire. Just seems odd cause the relay should be getting power from 12 volt constatnt, and ignition source and has a ground.
If i just jump the fuel pump while turning the key it still doesnt fire, im guessing cause maybe the injector resistor boc isnt getting power?
Idk where to go from here.
The car has a hondata piggy back and i guess i need to hook up my computer and play around, but i really havr no idea hoe to operate all that .
Help!
kratemertyl is offline   Reply With Quote
Old 11-11-2017, 07:21 PM   #2
sonikaccord
You are missing a very important wire in your diagnosis. What is the GRN/BLK wire showing for voltage?
Old 11-11-2017, 07:55 PM   #3
kratemertyl
So interesting,
My volt meter decided it was a good time to break.
So with a test light, if i clip it to a ground and then put the probe on the green and black tracer wire with the ignition onthe fuel pump turns on. But it barely lights up. The black wire with green tracer doesnt show any voltage either
Old 11-11-2017, 08:06 PM   #4
sonikaccord
That makes sense. The test light is effectively grounding the fuel pump part of the Main Relay. The fact that the pump turns on when when you probe the GRN/BLK wire, leads to the ECU either not turning the pump on or a break in the connection to the ECU.
The BLK/GRN wire is the Starter Signal that tells the ECU to turn on the fuel pump when the key is in start.
Old 11-11-2017, 08:10 PM   #5
kratemertyl
So the blk/green is supposed to send a signal to the ecu not the other way around?
I see in the schematic that that blk/green intercepts with something called starter cut relay #1
Not sure what this is
Old 11-11-2017, 09:18 PM   #6
sonikaccord
Yes. The Blk/GRN wire should have 12V when the key is in start, IIRC.
I would focus on the pump not priming first, as I think that tells us a bit more.
The starter cut relay is for the clutch switch. It shouldn't affect priming.
Old 11-12-2017, 08:46 AM   #7
kratemertyl
The black/green does not show any voltage. It does not have any voltage at the pin of the ecu either.
Im thinking i need to look into the ecu. Not sure how to do that though.
Any hondata guru's out there?
Old 11-12-2017, 10:38 AM   #8
sonikaccord
Did you press the clutch in, then check the voltage on BLK/GRN? The clutch interlock switch provides the 12V to that line.
During the first 2 seconds of ignition on, what do you see on the GRN/BLK wire? It should be 0V when the fuel pump is running or priming, 12V when off.
Old 11-12-2017, 11:31 AM   #9
kratemertyl
i will check that out tomorrow when I get home. I have the clutch neutral safety switch disabled but I will make sure its doing what it should. I thought if the clutch wasn't pressed in, that the ignition wouldn't turn the car over? and that the fuel pump would still prime
Old 11-12-2017, 01:44 PM   #10
sonikaccord
That's right. The fuel pump should prime as soon as you turn the ignition to ON, and it should go stop priming at the same time the CEL light goes off. That makes the clutch voltage a secondary issue and the GRN/BLK wire voltage is the primary suspect.
The fact that you can turn the pump on with the test light is a strong indicator that something upstream of the main relay is acting up. It's literally only a wire splice/continuity and and an ECU to check. I'm not too familiar with Hondata. I guess you could turn the fuel pump output on and off from there as well?
Old 11-12-2017, 05:51 PM   #11
kratemertyl
Im pretty sure u can adjust how long the pump primes and im assuming u can see other stuff regarding the fuel pump. If somebody on here cant walk me through it im gonna call my tuner tomorrow and see if he can help.
Old 11-13-2017, 09:24 AM   #12
kratemertyl
Might have narrowed it down to ecu
Grn/black shows its an active ground when ingnition is off and when on. Im pretty certain when the key is on this wire is supposed to un ground (excuse terminology) at the ecu. And its not
Is that right?
Or is this a bad wire thats grounding out amd its not supposed too?
Old 11-13-2017, 05:42 PM   #13
sonikaccord
That's right, the ECU should should "release" the ground for the GRN/BLK wire when the fuel pump is NOT running. When the ECU request that the fuel pump turns on, it grounds this wire and in turn causes the main relay to send power to the fuel pump.
It should read battery voltage when the ignition is on and when the main relay gets power.
To determine if the wire is grounded, disconnect the Main relay and connector A(26 pin connector) from the ecu and check for continuity to ground
Old 11-13-2017, 09:35 PM   #14
kratemertyl
Will do, went to 3 different stores today trying to find a good multi meter preferably a fluke but was unsuccessful. Gonna try a snap on truck tomorrow.
Old 11-14-2017, 02:42 PM   #15
PakaloloHonda
PakaloloHonda is cool... so far.
Send a message via AIM to PakaloloHonda Send a message via Yahoo to PakaloloHonda
wow, I might be having this very same issue ... subscribing, keep us informed krate ..
PakaloloHonda is offline   Reply With Quote
Old 11-30-2017, 04:03 PM   #16
kratemertyl
so maybe I don't follow what your saying,
ran a few more test trying to eliminate on or the other and heres what I got.
when key is on blk/grn does not release from ground
when key is on grn/blk goes to ground.
tested the ground wire of ecu and its good.
checked continuity of grn/blk, its good
checked continuity of blk/grn, its good
checked continuity of ground from ecu to relay, its good
tested the starter cut relay and its good.
I'm not a electrical genius so I'm having a hard time looking at the schematic and determining whats what. I wish I knew what wires were sending a positive/negative signal and which are receiving signal. like, between the ecu , the main relay, the starter cut, and the clutch interlock. I feel like I could chase it down if I knew the flow path once the key is on.
I don't have my old f22 ecu. if so I would jus plug that in and turn the key and see if fuel pump turns on. that would tell me if my ecu is good or not.
I'm not sure which way to go, except start all over
Old 11-30-2017, 05:52 PM   #17
sonikaccord
I drew a *really* crude schematic. I hope it helps!
EDIT: Also, the YEL/BLK wire "holds" the fuel pump relay on, while the BLK/GRN wire "turns" it on. I'm basing that off of the fact that the main relay in the schematic has a resistor and a diode attached to the fuel pump relay coil. This limits the current flow (resistor), in one direction (diode) to the fuel pump relay coil.
The BLK/GRN wire, only has a diode which means the fuel pump relay coil gets full inrush current from the clutch interlock switch.
Fun fact, an inductive coil spikes in current when a voltage is first applied to it, then it comes down to a low amount.
Old 11-30-2017, 07:25 PM   #18
kratemertyl
awesome man, this is really helping paint a full picture, but what is OV referring to?
Old 11-30-2017, 07:51 PM   #19
sonikaccord
0V is zero volts. Sorry about my trashy handwriting.
Old 11-30-2017, 08:48 PM   #20
kratemertyl
got ya. 0v. I was thinking ov.
tomorrow I'm going to take all this info and start over.
hopefully with this I can narrow it down.
in all actuallaity from all I have done its prob enough info to say its the ecu.
do u think if I took the ecu (as far as the main relay is concerned) out of the equation and sent 12v to yellow and 12v to yel/blk it would run?
