What's up guys? Alright I have jvc deck and a 1000watt kicker amp. Everytime I turn the volume up and the bass hits the deck shuts off Ive alredy checked the ground for the amp and its secure. Does anyone why my deck maybe shutting off.
Stereo shuts off at high volume
mine does the same thing.......
MRT Thread: http://www.cb7tuner.com/vbb/showthread.php?t=193631
My fs thread: http://www.cb7tuner.com/vbb/showthread.php?t=190359
Originally posted by JNizzle918 View PostWhat's up guys? Alright I have jvc deck and a 1000watt kicker amp. Everytime I turn the volume up and the bass hits the deck shuts off Ive alredy checked the ground for the amp and its secure. Does anyone why my deck maybe shutting off.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by JNizzle918 View PostAlso when my bass hits the lights dim. But I took the alternator to get checked and I was told it was good. So I should the deck ground wire.
edit... The dimming is normal when your running a 1,000watt amp.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by JNizzle918 View PostCould it also be that I'm running the power cable, the remote wire, and the rca wires on the side of the car.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by JNizzle918 View PostAlright ill definitely check all the deck connections. My deck is wired direct to the battery could it be that it has the wrong fuse the fuse holder. I barely found the fuse holder today while I was putting in a new main relay.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
I don't understand why people throw on 1k +hour watt systems, then wonder why their headlights dim, electronics power on/off, or their batteries die quickly.
After 600 watts of rms power a cars stock charging system is usually taxed, additional current is supplied by the battery. A strong battery can deal with this to a point, but it will greatly decrease its lifespan.
Try this, rev your car to 5 grand. Play a song at a level that a standard idle cannot supply he power for, see if it quits at that rpm. I bet it doesn't. This means your charging system is inadequate for the system you have installed. I would presume its even worse at night when you must run headlights.
Installing a capacitor will not help.
Originally posted by MortsAccord View PostI don't understand why people throw on 1k +hour watt systems, then wonder why their headlights dim, electronics power on/off, or their batteries die quickly.
Sounds like you are drawing to much voltage and your factory charging system is having trouble keeping up. You have a couple of options really.....
add a second battery
get a higher output alternator
run a capacitor
The capacitor is going to be the cheaper of the 3 but really isn't the most efficient way to go. It's like putting a band aid on a bullet wound.
Also if you are running a 1000wtt system then you need to make sure your power and ground wires are big enough. If you went to Wal-Mart and bought an 8awg power kit or heck even a 4awg kit you probably don't have a big enough wire. Your system will only be as good as it's weakest link. You can have a million dollar bad ass system but if you use cheap wire you will have these kinds of issues.
You need a quality 4awg power kit to help with your problems. Think of it this way: You are trying to drink from the water hose but you have it crimped off.
