Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Appearance
Old 08-10-2013, 12:48 PM   #1
stevenlo7253
stevenlo7253 is cool... so far.
Spoiler repair and install
I just recently bought a used spoiler and I am now trying to install it. When I tested the lights, a few of the LEDs were out. I was wondering if anyone knows how to open it up and fix the LEDs. Also, I read the diy on how to install, but am still a little confused. I see the notch in my trunk to drill, but my spoiler has a bolt and a screw on each side. Do I need to drill holes for both? or do i just screw the screw all the way in and just use the bolt?
stevenlo7253 is offline   Reply With Quote
Old 08-13-2013, 01:44 PM   #2
Strifecore
Strifecore is cool... so far.
Do you know how to use a soldering iron? I'm not familiar with the CB7 spoiler as i haven't owned one yet but a buddy of mine fixed his CD5 spoiler that had a few broken led's by purchasing new ones either on Ebay or RadioShack and soldering out the old and in the new. You can get a soldering iron for less than $10 and they are a good thing to have for such repairs. Good Luck!
Strifecore is offline   Reply With Quote
Old 08-14-2013, 08:23 AM   #3
stevenlo7253
Yes I know how to solder, but I'm not sure how to open the light housing. It looks as if it is glued together, probably to keep any water from getting in.
Old 08-14-2013, 12:01 PM   #4
Losiracer2
My car used just 3 10mm bolts from the factory for my EX spoiler.
I just recently put on my SE Coupe spoiler which had studs in front, but when I got it at the JY the previous owner filed them down flat.
It'll be fine with just 3 bolts.
member's ride thread
99' Lexus LS400 148k VVTi V8 gets up & goes...new DD
97' Lexus LS400 298k.....selling soon
96' Honda Odyssey 196k miles...$485 spare van for my parents
Old 08-15-2013, 08:15 AM   #5
stevenlo7253
Thanks, now I just need to see if I can fix the LEDs, and then I have to paint
Old 08-16-2013, 01:16 AM   #6
Losiracer2
I took mine this past weekend to Maaco and for 50 bucks they did an incredible job, even color matches perfectly to my weather beaten paint. They did a Dupont 2 stage base/clear paint job on it. Everyone else wanted at least 150 to do the same work. Took them less than 3 days to do it as well. Dropped it off Thursday afternoon, got it back Monday afternoon.
Old 08-16-2013, 10:55 AM   #7
stevenlo7253
Hmmm, I'll check it out. I was originally planning on just painting it myself, but maybe it'll be better.
Old 06-21-2016, 03:43 PM   #8
TKizzll
TKizzll is cool... so far.
That's awesome! I just picked up an OEM spoiler as well from a junk yard. Was thinking of doing it myself but that's not too much money at all. Definitely doing this.
TKizzll is offline   Reply With Quote
Old 06-21-2016, 03:47 PM   #9
TKizzll
Wow, nevermind I guess. My local Maaco wants to charge $250. Lol!
Old 07-03-2016, 09:24 PM   #10
Losiracer2
Ouch! That's a lot. I think I paid 250 for a high end shop to paint a front bumper for me, but it was new and they didn't have to remove any paint. I would keep searching, there are reasonable shops out there. Maybe the one you went to was busy with full body paint jobs and gave you a high price just so they wouldn't have to do it.
Old 07-04-2016, 09:27 AM   #11
Raf99
Not sure anyone answered his questions.
1. The LED bar is glued together and it is not possible to open it up to my knowledge without cutting through the plastic etc and making a mess. You could cut it open and fix the lights but its going to be easier to just find a spoiler with a LED bar that worked and grab it from a junk yard.
2. Installing the spoiler is tricky. There are two "bolts" on each end of the spoiler but only one location hole to drill on the underside of the trunk. Most will drill the one hole and cut the other bolt off the spoiler. To my knowledge one bolt goes through the trunk and gets a nut and the other bolt doesn't reach all the way through the two layers of metal and is just a guide bolt. There's also the middle hole which has no hole and you must figure out where to drill, the same goes for the wires and their access hole.
Even the below DIY doesn't mention that each side of the spoiler has 2 bolts.
OEM Spoiler Install w/ pics DIY:
http://www.cb7tuner.com/vbb/showthread.php?t=74918
diy , install , led , repair , spoiler
