How to make 30+hp for $500 or less... (DX/LX F22A1 only)
This topic is closed.
This is a sticky topic.
    Originally posted by accord junkie
    to the black yellow off the distributor, or another 12v source
    The H22's AIB circuit that opens the short, high-rpm runners in the intake manifold also gets added by tapping the black/yellow wire from the H22's plug to the same color wire that goes to the distributor in the Accord's harness. This simply supplies power to the AIB solenoid. The pink signal wire goes from the AIB solenoid back to the subharness/ECU at pin A17.
    oh wow geez thx for confirming that with a strong answer i had a feeling that it hooked up like that but wasint 100% sure thx i will run a function test as soon as i get a descent day outside and again thx
    The quote button makes things a LOT less confusing!
      heres a question. some people say you can hook the IABs up to a vaccum sorce on the IM and they will still work. what vacuum sorce can i hook them up to and they will still work?
        If you hook them straight to a vacuum source, they will open as soon as you go near WOT, or advance the throttle rapidly, regardless of RPM.
        It defeats the purpose of even hooking them up.
          On the A4 Header you guys are forgetting the downpipe aswell
          Its a totally DIFFERENT design, until it hits the cat
          4-2-1 its the setup, 4-2 then you connect the downpipe that goes 2-1-O2 Sensor
          Im about to do this swap and the the P12 ECU
          Your man for wiring solutions!
          CB7Man's Coupe H22 Swap
          CB7Man's Sedan Resurrected From The Dead
            i understand that but it still doesnt answer my question tho.
              Yes they sort of work, and you can use any vacuum nipple, or if one isn't free, "T" off another
                there is a video thread where the dude did this and ran it inside his car to diminstrate when they kick on. i dunno where it is though.
                "Self Renewed"
                  Sure it did. You hook it up to a vacuum source, any vacuum source, and it'll open the IABs at WOT.
                  I wouldn't say totally worthless, since you'd still get efficient partial throttle, but you'd bog if you floored it at 3000 until the airflow picked up. It's not a great idea. Removing the IAB plate would be a better idea, honestly.
                    Different design than which?
                    The A6 is also 4-2-1, and in at least some cases, the downpipes are identical.
                      so just remove the IAB plate all together? wouldnt that hurt the bottom end power?
                        Yes, which is why you should hook it up properly, or not at all.
                          so i have to get a A4 downpipe as well? I just got a A4 header it looks like from a parts car that had it laying in the passenger seat. Luckily the A4 and A6 downpipe is the same as i read so all i have to do is fine one of those. do i need to get the O2 sensor that is on it as well?
                          Instagram: n_buttz
                          The Jeepster ____ The CB7 ____ The TE38 ____ The S13
                            There is a possibility that the bolt holes for the downpipe are not drilled the same on the A4 and the A6.
                            I have seen some A6 downpipes bolt up to the A4 upper manifold, but Fizzbob says he has seen some that don't.
                            The easiest way to avoid that problem would be to make sure you get the whole thing from the same car, or double check the patterns before you buy.
                              i was wondering if i can net any gains by doing this... i have a full h23 headswap on my a1 block
                                Since you have the H23 headswap, you should already have the H23 intake manifold... and the H23 exhaust manifold is probably better suited to the head than any F series one.
