one reason to make sure you take the proper steps with your motor
    i was on H-T and i came across a blown motor thread. guy was spraying nitrous on his B20. must have done something wrong and blew up his motor. he thought it was the worst. heres his:
    no this piston was NOT taken out of the motor....
    i was like. dag. thats pretty bad. then i went on to the next page or 2 and then i saw the worst blown motor ive ever seen in my life. its graphic so any of you gear heads might throw up chunks if you see it.....scroll down at your own risk....
    this from a motor with a snapped CRANK. thats right. a snapped CRANK. i didnt even know those things could snap:
    You and your prophetic warning threads are starting to scare me.
      only to make sure you do your car right and not in a rush
        The bottom one with the broken crank looks like someone dropped it.
        MR Thread
        GhostAccord 2.4L Blog
        by Chappy, on Flickr
          the block that it came out of doesnt tho. lmao
            Those are some sad sights to see. Just be careful!
            Always remember that only you can make your dreams a reality.
            Never forget that your style is all that matters when it comes to your ride, but be respectful to others who don't share your vision.
            Proud Alum of the University of Texas at Tyler, Class of 2010
              dayummmm!
              Originally posted by Juice21
              thnx pimpette, your car inspired me to go lower
              Originally posted by GameChewer
              Shiit i heard that, you heard the queen!
                Was that crank knifed edged? Ive heard that can weaken them enough to break..
                  from the photo i would say it was and
                  PSN ID's:Tidashoni
                  1992 Accord EX Coupe
                  My FS Thread
                  Not so DD 2013 Subaru Impreza WRX STI
                  Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
                    Thats very odd to happen to the block like that...what i'd be interested in seeing is where is that 4th cylinder sleeve or the remains of it at?
                    "Once a CB7 Tuner, Always a CB7 Tuner"
                    Former h23 swapped accord owner...
                    2002 Acura 3.2CL
                    20" Rims and Brembo Brake Kit - Ridin classy and slow
                    1994 MKIV TT Supra
                    BPU+++ (under the knife, getting nastier)
                      Negative. I've dropped cranks before(on purpose) and they won't fucking break.
                      That looks like maybe a bearing got too hot on one of the mains, melted and probably the bitch snapped. That motor looks like it had sleeves and forged pistons as well. I wonder if it was an aftermarket crank.
                      PR CB7 just got a motor from tigerjap with a snapped crank.
                        thats all tuning.
                        I <3 G60.
                          tuning would cause holes in the pistons and or valves.
                          The first one looks like the timing belt slipped somehow or a misshift. The 2nd one looks like building error.
                          I've had the 1st one happen to me, except on 1 cylinder only. Timing belt slipped on my motor at idle. Somehow.
                            And that second motor is what would've happened if he tried to start it! Good thing it was taken apart and inspected first.. most people don't do that!
                            When the block blows apart like that, parts leave the engine... very hot parts. Very fast moving parts. That engine isn't all that far away from you, and the firewall, hood, and windshield are much weaker than the block that those bits just broke out of... I wouldn't want to be in a car with a grenade like that under the hood!
                              here's mine
                              Just do what PR CB7 said.
