Loss of power
    Loss of power
    My 93 auto seems... slow. It hits a wall after 80 and completely tops out at 107, and that took a LONG time to get there. I deleted the old cat so thats not the issue. I hear alot of people with stock auto CB7's getting over 130. What could be the issue?
    Why are you trying to go 130mph?....
      Because racecar. But thanks for helping with the question! Appreciate it breh!
        Where do you stand on normal maintenance? You know your engine has good compression? Clean air filter? Clean fuel filter? Correct fuel pressure? Good plugs, cap, rotor, wires? Ignition timing? Valves adjusted correctly? Brakes not dragging?
          Very good questions. New plugs, wires, cap and rotor. New air filter. Unsure of ignition timing or compression. Old fuel filter and unsure of fuel pressure. I have thought about the valves being loose but there is no valvetrain noise, I will check them as well tho. I checked brakes today after the pull, no sticking and all 4 hubs were cool after the long drive
          Thanks for jarring my head, I'll check the valves and do a comp and fuel pressure test tomorrow. Need to buy a timing light to test timing soon as well
            Definitely check the timing. It was off on my 93 Auto when i first bought it 2 months ago. Then I put it back on point with my timing light, and man it really woke up that f22. Like a whole nother car
