EX to SE dash swap... What am I in for...?
    I've been considering and finally deciding to make a move on swapping my ex dash for an SE. What do I need to know before going into this and is it possible to make the passenger side airbag work and where do I begin to make it work?
    Thanks!
    Current
    1992 Accord EX 5-speed Sedan
    Rosewood Brown
    1992 Accord EX 5-Speed Sedan
    Arcadia Green
    Previous
    Bordeaux
    1993 Accord LX 5-Speed Sedan
    Bordeaux
    The dash it self should swap directly. You might need to grab the airbag harness also.
    1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
    Originally posted by keepinitclean
    I give it 2 weeks before you sell it.
      If you want the passenger airbag to work you will need to swap the airbag harness and airbag ECU out.
      The airbag harness is seperate from the oem harness. Its been something on my to-do list for awhile but i have not gotten around to it.
        I can't remember how many times someone asked me for my dash when i had my 93 SE lol.
        Yaaa your going to need the harness and ECU.
        Be careful when doing the swap, as if miswire it you might deploy the bag.
          you shouldn't be wiring anything
          You should be unplugging the SRS harness and unclipping it from under the dash and cliping a dual airbag harness in place.
          be sure to disconnect the battery when doing any SRS work.
            Yes but on my car there was a pin that needed to be plugged in in order to prevent the bag from firing and the battery needs to be disconnected.
            I should have worded it better...i didn't mean like re wiring....i meant like connecting everything....
            just be careful lol.
              Thanks for all the help! Hoping it goes as easy as it sounds! Also, what "order" are you referring to when re-hooking everything up?
              Current
              Rosewood Brown
              Arcadia Green
              Previous
              Bordeaux
              Bordeaux
                You're also going to need to weld in brackets to mount the airbag to if you want it functional.
                  make sure the harnesses are compatible. my 90 dx was not compatible with a 92 harness
                    I want my cb to have dual airbags. This must be pretty rare, I have never seen one before. Be sure to post pics or even a diy if you actually do it.
