CB7-X1 version 1.0 almost ready
    Today I was finally able to road test my first non-stock preparation of a CB7: a 93 LX. After a few test runs I finally put the pedal down in first (rolling start). I thought the clutch was slipping but no, I had just run the gear that fast. Definitely a seat of the pants noticeable difference from stock.
    The rundown:
    F22A6 swap (replacing my 300k+ mile A1)
    Ebay header/downpipe
    EX muffler assy
    PT6 ECU
    Stage 1 clutch
    10# Flywheel
    Interior Lightened
    Poly windows
    Deleted: A/C, power steering, alternator, heater, cruise control
    Bolting on soon:
    Koni orange w/tein H.Tech (~1.2" drop)
    (Front - 4 kgf/mm 224 lbs/in; Rear - 2.7 kgf/mm 151 lbs/in)
    EX rear sway bar
    Also, still need to wire the IAB.
    And put a turbo on it
    Note: Fuel pump access hatch
    93 Seattle silver sedan like mine.
    I see a Linn county plate. That's one county north of me as I'm in Johnson.
      Yeah, about half of it still has paint on it, lol. I'm sure you'll all be shocked to hear that aesthetics are not a priority for this build.
      Hey H311 what do you think about a CB7 meet up in the corridor next summer?
        Rust...natural weight reduction. I like it. It's going to be a lot of upset people getting beat by this.
        YouTube Clicky!!
          Depends on specifics really. I'd be more likely to attend something of the like if it were of a reasonable size. Which has been the issue with the ones I've attended in the past.
          You ever need a hand with something CB related feel free to contact me. I can't guarantee I'll be free or able or promise you anything but I'll see if I can try.
            Theoretically some body work will be done at some point, but purely for aero reasons. I kind of like the fading paint/chipping clear coat. Not to mention that a cars worth of paint can easily weight 40lb. My build theme: Ugly is the new pretty.
            @H311RA151N Hey same for you, if you ever need a hand or want to pick my parts pile just shout.
              Another Iowan checking in. Des Moines here though.
                No dashboard? Oooookkayyyyyyy
                You going to chip off all the insulation/sound deadening in the interior? What about the firewall pad, that thing is HEAVY.
                Inspections must be lenient there, I can see at least one reason you would fail here. Driver's window does not roll down.
                1992 Accord Wagon (RETIRED)
                  Wait, you can fail an inspection for that? Do they have a sign saying "It Is what it is" too?
                  YouTube Clicky!!
                    Iowa has no inspection or smog whatsoever lol
                      Thats honestly scary. As much as a pain in the ass a safety inspection is, it keeps the stupid people in check.
                      And yes, some of the things required are annoying. I had one guy fail a car because the windows rolled down too slow I had to point out to him that the inspection code does not state a minimum speed for the windows then he put the sticker on.
                        Lol yeah we have some shitty cars running around....lol
                        if that window case is true my 8th gen would fail that speed test as well going up lol, I need to lube it up.
