Old 08-14-2011, 09:43 PM   #1
tonka9999
tonka9999 is cool... so far.
Question Porting the H23 IM or Double stack? or Both
I just got my second H23 IM
"Double Stacking" is an option that i have ... but what if you where to port the IM as well. So have the IM double stack and ported...? has any body tried it? If it worked is there a DIY on how to Port IM? Thanks
tonka9999 is offline   Reply With Quote
Old 08-14-2011, 09:53 PM   #2
deevergote
Don't call me dude.
I wouldn't bother porting the IM. I assume this is going on an F22A... The manifold will flow just fine. Too much airflow, and the engine won't know what to do with it.
Old 08-14-2011, 10:29 PM   #3
tonka9999
That make since... hey it a smaller Pic this time Im learning! haha Thanks
Old 08-14-2011, 10:35 PM   #4
The G-Man
The G-Man seems to have made some friends!
Send a message via AIM to The G-Man
especially if you are not tuning the ECU.
Gary A.K.A. Carter
[sig killed by photobucket]
The G-Man is offline   Reply With Quote
Old 08-14-2011, 10:43 PM   #5
The Producer
The Producer is cool... so far.
You could try extrude honing. That allows the best possible porting, provided you still wanted to go that route.
The Producer is offline   Reply With Quote
Old 08-14-2011, 10:45 PM   #6
deevergote
Don't call me dude.
Damn Gary, haven't seen you around in a bit!
That's true... but that's probably a good deal out of his price range. Extrude honing is stupid expensive.
Old 08-14-2011, 10:52 PM   #7
The Producer
I guess that explains why I've only read about it!
Has anyone on here done it?
Old 08-15-2011, 01:33 AM   #8
cloudasc
cloudasc is someone to admire cloudasc is someone to admire cloudasc is someone to admire
If your going to do anything to the intake manifold, the term you want is flow balancing and gasket matching. The service I had on my intake manifold was just this, and the imperfections in casting were smoothed out/removed. To take full advantage of the gasket matching, I would also need to have intake side of the head ported/gasket matched as well.
cloudasc is offline   Reply With Quote
Old 08-15-2011, 03:34 PM   #9
tonka9999
ok what about just gasket matching the two IAB spacer's and TB?
Old 08-15-2011, 03:41 PM   #10
cloudasc
CHRRacing is where I had my intake manifold flowbalanced/polished/gasketmatched. The IAB spacers do not even need to be modified. If my throttle body had been bored, CHRRacing would have matched the opening of the throttle body to the plenum as part of the service also.
Hybrid Intake:
A6 Runners w/Flow Numbers:
Plugged gutted IAB spacer:
H23 Plenum
Old 08-18-2011, 06:00 AM   #11
tonka9999
Good help
Im going to try do it all my self...at least polishing them! Thanks for the info and pics!
double stack , h23 , porting im
