Rebuilt motor and just set timing belt but will not start anymore
    I've been kind of off this thread for a few days, been busy.
    Starting to think simple fixes that may have been overlooked.
    Are all your spark plugs torqued down? All that compression could be slipping past un-torqued spark plugs.
    Are you sure you have a compression tester that works? It sounds like you're engine has no compression in the video, so I doubt this but it never hurts to check.
    Have you checked your rotor's position when it's on TDC, just want to make sure it's all lined up?
    Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
      i have one but it don't work it don't hold the air in it
      https://flic.kr/p/ELMAhy
        The rotor? and yes spark plugs have been torqued down
          Originally posted by zZcommandoZz View Post
          I missed this post, sorry. The movement looks good. Was the number 1 piston in sync with the intake and exhaust valves?
          YouTube Clicky!!
            The rotor?...
            The rotor, as in distributor rotor (sorry I wasn't clear).
              Commando, you said you rebuilt the motor. Exactly how far did you have it disassembled? What operations did you perform?
              If you were doing anything with the pistons, did you make sure and stagger your rings? If you lined them up, compression will go past them into the crankcase.
              My '91 LX build. Bought September 2017. Sold June 2020.
              http://www.cb7tuner.com/vbb/showthre...r /> t=209871
                just all head work and new valves and stem seals
                  Commando, you never answered this question. In the video, you didn't mention if you'd set the #1 piston to TDC and where your cam was positioned at that point. The word "UP" on the cam gear should be facing up when at TDC.
                    https://youtu.be/_nrs0bJcjs0
                      so how it look?
                        I'd say check the compression in all 4 cylinders to see where they're at. From the sound made and the ease you're turning the motor, it seems like you don't have compression in any of your cylinders.
                        If that's the case, might need to pull the head back off and reassess what's going on. Maybe they installed your guides incorrectly or even the wrong ones; or they didn't make sure your seats were cut right and the valves aren't closing fully.
                        Definitely do a compression check before you do any of that.
                        What head gasket did you use?
                          leak down test
                          ok im am going to do a leak down test tomorrow as soon as im out of work and will let you guys know what i find out
                            https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
                              leak down test results
                              https://youtu.be/EbyoSSEeMIk
                              at TDC you can hear it coming out of cylinder #3
                                leak down test redo
                                https://youtu.be/EDn-gZnxKbI
