#1 |
Newcomer
Steering wheel play
I have a good amount of play in my steering wheel. Want to know if anyone has ever experienced the same issue and knows of a solution. My wheel is VERY easy to turn about an inch or so from side to side, same goes for the actual tire/wheel while attached to the car (in the air) shaking it side to side. I have replaced BOTH inner and outer tie rods on each side. This did help a little bit (they needed to be replaced) but did not completely fix my steering wheel play. I suspect it could be an issue inside the rack itself or possible a bad steering shaft? Any input would be very much appreciated.
Thanks |
#2 |
Contributing Member
How many miles on your car? When you turn the steering wheel (with tires in the air), do the tires move with the wheel, or are you saying there is that much movement in the steering wheel without any motion at the front wheels? When you say you are "shaking it side to side", do you mean rotating the knuckle left and right? Is this with or without the engine running? How does it compare to when the car is on the ground?
Remove the cover on the inside of the firewall at the bottom of the steering column to view the coupling between the steering shaft and the pinion shaft to make sure the clamp bolts are tight and there is no play in the coupling.
__________________
90 LX 4dr 5 spd 366,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450 93 LX wagon auto 247,000 MRT:http://www.cb7tuner.com/vbb/showthread.php?t=208490 92 EX coupe auto 168,000 - MRT:http://www.cb7tuner.com/vbb/showthread.php?t=205114 LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583 Last edited by fleetw00d; 03-16-2017 at 08:58 PM. |
#3 | |
Gold Member
Quote:
#4 | |
Newcomer
Quote:
#5 |
Newcomer
So I have the same problem in my wagon too. At this point the whole steering and suspension is new or close too.
I even replaced the column with a low miles one from the junkyard. It helped but still like 5 degrees of play. (the bushings internally where it collapses were shot. just fell out when i took it apart) So at this point I gotta say its the rack itself. 235k on my accord. so not totally surprising. |
#6 | |
Newcomer
Quote:
#7 |
Contributing Member
There is an adjustment on the rack that controls the engagement of the rack with the pinion. Instructions on how to adjust it are included in this thread: http://www.cb7tuner.com/vbb/showthread.php?t=207857
I will finally be replacing the original rack on Ruby @ 352,000 miles next week with a rebuilt one from Honda, p/n 06536-SM4-515RM. Includes boots and inner tie rod ends. Other tasks: power steering pump, rear upper control arms, rear Bilstein shocks. I probably should do bushings in the lower control arms as well.
__________________
90 LX 4dr 5 spd 366,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450 93 LX wagon auto 247,000 MRT:http://www.cb7tuner.com/vbb/showthread.php?t=208490 92 EX coupe auto 168,000 - MRT:http://www.cb7tuner.com/vbb/showthread.php?t=205114 LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583 Last edited by fleetw00d; 03-20-2017 at 09:41 PM. |
Tags |
play , rack , steering wheel , tie rods |
Thread Tools | |
Display Modes | Rate This Thread |
