marcusv8thunder : 1993 Accord 2.0i
    Yet another booty shunt! This time it was a work truck Manovering. Rear bumper has been hit so many times, and nothing else behind it gets damaged, I am lucky with this. Still gutted to come out to the car to see this though
    Better call the paint shop!
    UKDM 93 CB3 Page (1) H22A U2Q7 LSD
    UKDM 91 4ws Page (3) OEM Minter
    NOW H22A U2Q7 SWAPPED
      man that sucks big time. come back harder marcus! i bet you got the paint shops number on tap in case of emergencies like these
        good luck with the repair, and when you taking it back too the track?
        CB7TUNER.com
          Yes tommi, Ive do have the number in my phone, I called today and the bumper and little piece under the light is getting sorted on Thursday, hopefully Ill get it back next week.
          Await some pics of a shiny new booty!
          Cheers I have popped the bumper out, looks fine, the paint is gone all over, so it will be a whole bumper prep and respray.
          I have a little exhaust work to finish, need to redo the mid section to rear section join better. Then it is good to go for a trackday again.
          In the UK trackdays are cheaper in the Winter, becuase of the higher chance of bad weather and the light fading toward the end of the day. So ideal time to grab a couple of blasts for cheap.
            Well this incident has called me to transfer to the "WEC" Winter Eco Car.
            Honda Civic
            So in the mean time I can spoil this very Germanic workshop and park the Accord for a bit.
              i'mma come visit u at silverstone sometime.
                Holy crap, that's a clean shop.
                  You are more than welcome!
                  I wish I could own a place like that one day! Its just where I work.
                    Lucky you! That's a sweet shop.
                    '93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
                      Accord is still in the workshop so ive pulled the exhuast off for some custom alterations. Then I can get driving it again. Missing it majorly!
                        Well the bumper is back on, has been sorted a while but the Accord ran out of MOT, then tax, so sat in the workshop for a while.
                        Also while I had the car there I thought Id sort out the front torque mount which was tired even before the swap, the H22a had finished it off lol.
                        I didnt like the engine twist delay between shifts, and 1st gear slow speed part throttle on/off throttle (like in traffic)
                        So instead of blowing money on a new one, which wouldnt be rated to the H22a anyway, I bought some 60 shore rated poly rubber. This is about as stiff as the OEM rubber, but becuase it filled all around its stiffer.
                        So with a fresh MOT and some tax, Been driving around with it this week, and what a difference! Big improvement, for a £15 for bottle of rubber to be so effective I reccomend this. http://www.ebay.co.uk/itm/Polytek-Po...item35ba4dd09b
                        Before
                        After
                        Just mix it up pour it in, make sure you tape up/seal the other side!
                        I prepped/tided up and sprayed black the whole lot afterward, but I havent pictured that.
                          The 2 part urethane works nicely for filling mounts,
                          I hope to see shots of this car on the track soon.
                          CB7TUNER.com
                            looking at the first track day of 2015 end of March.
                            Got some things to fettle with before then.
                            Mainly brake related, caliper re-greasing, brake bleed and rear pad change. and reroute the cooling duct hoses.
                            And mount the 225 45 17 Yokohama a048 semi slicks I grabbed on the front wheels.
                            Also bought a oil catch can, and clean up the pcv valve as it just started playing up. Hopefully with a cleaned up/new pcv valve and a oil catch can setup the oil vent system will be back upto scratch.
                              Fresh Brakes parts
                              Polished and greased sliders for quick reaction brakes.
                              Rear done
                              Front setup
