Go Back   CB7Tuner Forums > Parts & Performance > Appearance > Lighting
Old 01-12-2018, 01:19 PM   #1
wtfisafleek
CB7tuner Member
exterior door lock illumination
Since our cars didn't come with remote unlocking/locking, I find it tedious depending on how dark it is to get my key in the hole to unlock the car. I've seen on other cars in the past have had an illuminated bezel or even a light behind the key slot to make it easier to find in the dark.
Example, early 80s RX-7: http://foxed.ca/rx-7/jan09/small/DSC_0726.jpg
Or 80s Cadillacs: https://www.google.com/search?biw=13...zafB9LgGSDi8M:
Has anyone ever added this feature to their CB?
Old 01-12-2018, 01:34 PM   #2
cp[mike]
ĮĮĮĮĮĮĮĮĮĮĮĮĮĮ
cp[mike] is very helpful cp[mike] is very helpful cp[mike] is very helpful
interesting idea!
I think most people tend to just get keyless entry instead. In fact, a while ago it was a popular mod to use sedan rear door handles swapped to the front to completely eliminate the locks altogether...
Anyway, in terms of the CB locks, the first idea (the key slot itself) wouldn't be very easy, as the CB has a metal flap covering the hole to keep dirt and rain out. It looks like on the RX-7 either the flap is left off, or is made of plastic - it would be tough to make a plastic replacement that tiny. The second idea (a ring around the outside) would also be tough because the CB locks are recessed without a protruding bezel, and require the key be inserted all the way - though I would imagine a variation of this idea might theoretically be doable. Perhaps inserting a clear plastic 'washer' in front of the cylinder itself, but behind the metal trim (pushing the cylinder back slightly) with an LED pointed at it from the inside? Or maybe the entire metal trim can be pushed back a bit and a ring added around the outside of that (similar to the ignition light ring)? Or maybe just the bezel ring from the GM one added to the CB making it stick out? In the case that any option causes problems with the key no longer being long enough, you could get a newer (specified as the 94-97 part) OEM honda key, as their stem is a little bit longer.
Personally I would prefer the lock hole be entirely removed, with a Ford-style numeric keypad <pic> mounted inside the recessed area under the handle, but I don't think a ford one would actually fit. Then, illumination could be mounted up inside the handles pointed downward... which, now that I think about it, illuminated handles <pic> on its own would be a cool mod.
Close-up of a CB7 driver door keyhole (sorry for the huge size) <pic>
I'd love to see something like this done because I enjoy these types of small detail mods!
__________________
cp[mike] is online now   Reply With Quote
Old 01-12-2018, 04:48 PM   #3
excalibur02
Wanna be JDM whore
Location: north new jersey Owns: Turbo cb6 & NA cb7 I'm: NJs 5-lug King ;-0
excalibur02 seems to have made some friends!
Send a message via AIM to excalibur02
very interesting!
Yeah definitely get keyless entry/ security for the car. After that you can do little mods like Mike said, lighted handle and or keyless door handle
__________________
Instagram username MAURO02
If my pictures do not work and you see ****.com replace it with m1xe.com
excalibur02 is offline   Reply With Quote
Old 01-12-2018, 09:56 PM   #4
Jarrett
Contributing Member
I'm definitely more for the illuminated handles. I got rid of all my sedan handles a while back, but I decided I wanted to do that mod again recently. I just keep forgetting to grab them at the yard.
I think the more yellowed light on the picture Mike attached looks better than the bright LEDs I've seen before.
__________________
Old 01-13-2018, 01:40 AM   #5
NH-503P-3
CB7tuner Member
NH-503P-3 is cool... so far.
I have a passive keyless entry with push button start. With the key fob in my pocket the car unlocks as I get up close to the door. Then locks after I walk about 10-15 feet away. I got rid of my handles with key locks. My fob does have a flip out key on the side to get into the trunk if I need to. Iíll just call AAA if something takes a crap anyways. The door locks look hideous. I love the way my car looks without them.
Now with this setup it would be cool to have the door lights under the handles. Iím assuming hitting the unlock button would make them illuminate.
Old 01-13-2018, 02:03 AM   #6
Jarrett
Contributing Member
If it's wired up that way. Many aftermarket alarms have a feature that taps into the dome line circuit so that it comes on when the vehicle is unlocked. If this lighting piggy-back that, it would work. However, in your case, that's just more wiring that needs to go through the doors.
__________________
Old 01-13-2018, 08:17 AM   #7
Raf99
Gold Member
Raf99 is very helpful Raf99 is very helpful
Always a dream of mine to have the exterior door handles light up. There's a 2016 cadillac down the road and it has exterior handles that light up. I've seen others where they are lights below the handles too. The only issue I have is that I'd want these to light up with the you hit the unlock button on the remote door unlock, so I'd have to have some kind of timer/relay on there to keep them on for 15+ seconds.
Here's lexus version too...
But one would have to do a professional job on these. Anything less and they'd look like the worst ebay crap.
Old 01-13-2018, 09:20 AM   #8
wtfisafleek
CB7tuner Member
That's a great alternative. What brand's kit did you go with?
Old 01-13-2018, 09:26 AM   #9
excalibur02
Wanna be JDM whore
Good point on the dome light option on the alarm. I currently have that setup in my red cb. Hit the unlock button, map light and dome light turn on until the car starts or the alarm is set to lock again.
Exactly more wiring going to the doors
__________________
Old 01-13-2018, 09:39 AM   #10
'93CB7Ex
Gold Member
'93CB7Ex seems to have made some friends!
Quote:
link to the kit you have?
__________________
'93CB7Ex is offline   Reply With Quote
Old 01-13-2018, 09:51 AM   #11
Jarrett
Contributing Member
My F-150 uses puddle lamps when the unlock button is pressed, instead of the handles. Maybe a white underglow kit could be added that only comes on when unlocked.
And when you're riding around with Uncle Ben.
__________________
Old 01-14-2018, 10:57 AM   #12
NH-503P-3
CB7tuner Member
This is the kit I bought. Itís cheap & easy to install. Instructions are lame but if you can install a stereo you can install this. I give it an 8 out of 10. As it likes to lock a lil too quick sometimes. Other than that it does itís job and I donít have to touch the key fob. Just keep it in your pocket like a new car. I leave it in my car as I work on it otherwise it will lock and unlock as I walk back and forth from it. Itís smart. But not that smart. Iím sure there are systems that do the same shit better. But Iím not willing to pay that much.
https://rover.ebay.com/rover/0/0/0?m...2F132452684368
Old 01-14-2018, 12:39 PM   #13
hiptech
CB7tuner Member
hiptech seems to have made some friends! hiptech seems to have made some friends!
Just curious... when you replace ignition switch with this push button start how do you override the mechanical steering lock?
BTW has anyone given any thought to adding an exterior trunk release switch located between the 2 rear license plate lights? I've really gotten used to this on my TSX...
__________________
My Collection:
93SE Sedan (Cashmere Metallic)
00EXV6 Sedan (Naples Gold)
04TSX 6-Spd Navi (Premium White Pearl)
hiptech is offline   Reply With Quote
Old 01-14-2018, 03:09 PM   #14
NH-503P-3
CB7tuner Member
I pulled the whole ignition out and set it to not lock. Thereís a position you can put the steering column in where it isnít locked then I cap the end with the old ignition backing piece. And it holds it in place so it doesnít move into a locking position. Itís easy to do.
