CEL Code Question
    CEL Code Question
    Last night my abs light turned on. SO this morning i tried to pull its code. I believe i get a 48 code for the abs and i also now get a 14 code for CEL lamp. 14 is iacv i believe and 48 for abs is rear wheel sensor. SO how is the cel code connected to my abs. I still have to check my abs code it gives me again as i am little confused by how that abs check codes work. The 48 it gave me is sort of a guess as the 4 and 8 were separated but the 4 blinks were short like the 8. Doesn't seem to work the same as checking codes for CEL. Does it?
    Do abs codes always blink fast. Like 48 is really 4 short blinks with a pause then 8 short blinks. That is how my abs blinks its codes i think. CEL long codes are easier to tell. Is this right. anyone else notice this? I am seeing different manuals say different things.
    CEL/ABS/D4-SLIGHT all burp out their codes at the same time theyre not related unless by code.
    ALB brain codes.
    Code / Fault
    1 Hydraulic pump motor over-run (contact BBA)
    1-2 Hydraulic pump motor (contact BBA)
    1-3 High pressure leak (possibly modulator)
    1-4 Pressure switch (contact BBA)
    1-8 Pressure accumulator
    2-1 Handbrake warning lamp switch circuit faulty
    3-1 Right hand front rotor damage
    3-2 Left hand front rotor damage
    3-4 Right hand rear rotor damage
    3-8 Left hand rear rotor damage
    3-12 Different tyre sizes fitted
    4-1 Right hand front wheel sensor
    4-2 Left hand front wheel sensor
    4-4 Right hand rear wheel sensor
    4-8 Left hand rear wheel sensor
    5-4 Right hand rear wheel lock
    5-8 Left hand rear wheel lock
    6-1 Front fail safe relay
    6-4 Rear fail safe relay
    7-1 Right hand front modulator solenoid valve
    7-2 Left hand front modulator solenoid valve
    8-1 ABS operation fault
    8-2 Electronic control unit (ECU) fault
    8-4 Electronic control unit (ECU) - internal circuit fault
