Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Appearance
Old 06-06-2016, 07:54 PM   #1
SedanTom
Newcomer
SedanTom is cool... so far.
Brake lights stay on after car is shut off
As the Title states, I'm having issues with just the brake lights staying on after the car is shut off, I tried disconnecting and reconnecting the battery to kind of "Reset" it but to no avail. I'm thinking it could be a relay of some sort, if someone could point me in the right direction that would be loads of help.
SedanTom is offline   Reply With Quote
Old 06-06-2016, 11:12 PM   #2
fleetw00d
Contributing Member
Do they shut off when the car is running and the brake pedal is released, or they on all the time when running as well?
Check the brake light switch where the pedal stops at the up position, it may just be out of adjustment. The brake pedal pushes the switch when completely released to turn off the brake lights.
__________________
90 LX 4dr 5 spd 380,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
92 EX coupe auto 193,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210341
07 Element EX AWD 183,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
INVENTORY REDUCTION! LOTS of CB7 parts for sale or FREE http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 06-07-2016, 12:28 AM   #3
Bolex
Newcomer
Bolex is cool... so far.
Check on small rubber piece is on his place on brake pedal.
Bolex is offline   Reply With Quote
Old 06-07-2016, 08:07 AM   #4
baracuda
Southern Regional Moderator
baracuda is cool... so far.
As Bolex said, look under the dash at the floor and you will most likely see crush plastic, a lot of people say it look like crushed m&m's. This plastic comes from a plastic numb that presses in the plunger on the brake light sensor when you let off the brake. The plastic numb would normally be mounted to the top on the brake arm and you will see a square hole where it should be located and the switch right above that. You can either buy a new one or what I did is got a small nut and bolt too make my own plug that I don't ever have to worry about breaking. I hope this helps.
__________________
Sold too: Grumpys93, '93CB7Ex, Bunta, prodh22accord, SSMAccord, fleetw00d
baracuda is offline   Reply With Quote
Old 06-07-2016, 10:36 AM   #5
SedanTom
Newcomer
Thanks guys, I will check after work!
Old 06-07-2016, 10:53 AM   #6
excalibur02
Wanna be JDM whore
Location: north new jersey Owns: Turbo cb6 & NA cb7 I'm: NJs 5-lug King ;-0
excalibur02 seems to have made some friends!
Send a message via AIM to excalibur02
Yeah your pedal pad stopper probably broke off. Look under the dash on the brake pedal and look at the solenoid push pin.
__________________
Instagram username MAURO02
If my pictures do not work and you see ****.com replace it with m1xe.com
excalibur02 is offline   Reply With Quote
Old 08-18-2019, 04:31 PM   #7
laloquera
CB7tuner Member
laloquera is cool... so far.
Happen to me today, found the cheap plastic culprit pieces on my floor mat. Gonna super glue it with backing soda and its gonna last another 27 years plus and then some.
laloquera is offline   Reply With Quote
Old 08-18-2019, 08:47 PM   #8
fleetw00d
Contributing Member
Quote:
One of the push clips for the front fender liners works pretty well too. Some folks put a bolt and nut in the hole.
Old 08-19-2019, 08:27 PM   #9
Grumpys93
Contributing Member
Quote:
Thatís what I did, never have to worry about busting a plastic clip again and draining your battery down.
__________________
~Nick~
