f22a1 to h22a map sensor wiring?
    Okay so I have been searching a lot and found some useful info on wiring but none seem to match my color on the wires? So I have some pictures hopefully you can help me wire this thing right. Thanks!
    I need help my plugs are getting fouled so quick. It wont stay running without half pedal and missing on 2 cylinders already even know new plugs
      Did you check or adjust your TPS?
      Did have any CELs?
      YouTube Clicky!!
        Just map sensor
          http://www.cb7tuner.com/vbb/showthre...h22+map+sensor
          Going off of what CyborgGT did, looks like your grn to grn/wht is good. Pink and white are reversed. Pink to yel/red and wht to red/whatevercolorthatis.
          Or simply, pink on left, green to center and white on right
            Yeah i ended up wiring that way. Still same issue i even replaced the map sensor. Now my car ia running on 2 cylinders, 3,4 not firinf. Replaced plugs and they carboned right up. Please somebody i need help im so close to giving up, driving me insane
              Have you thought that maybe the map sensor is bad? Just run the stock one off off a vacuum nipple.
                Yeah i tried a new map sensor. Im going to get the orignal map sensor. Can i use my f22 intake than it will fit so i can use vacum line?
                  Why didnt you just keep your stock map sensor? Like djcaz mentions you just need to connect it to an alternate vacuum source and block off the h22 map sensor location or better yet make your own adapter with some scrap metal, oring and a fitting. See the 2nd pic below, its pretty easy to make. It doesnt have to look as pretty as the examples below. Or you can buy one. I have the the one in the first pic below. Only because I wanted it to look purty. But when I first needed one, I made my own with some random pieces found in garage.
                    Ok i will do that. Can i just hooked up vacum line to any of the ports on the intake that are not being used? Also instead of blocking it off i can just leave the map sensor on tb connected right?
                      You can leave the sensor on there and just tap into a vacuum source on the manifold.
