Old 07-07-2013, 11:23 AM   #21
indoplasm
Newcomer
indoplasm is cool... so far.
When it doesn't start it will crank fast then to slow as it draws the last of the power from the battery
indoplasm is offline   Reply With Quote
Old 07-08-2013, 01:05 AM   #22
accordztech
CB7tuner Member
accordztech is cool... so far.
Send a message via AIM to accordztech
shouldn't matter if it cranks slow or fast, he isn't getting charged.
Follow the electrical wiring in the manual, trace the wire back to where it goes and test there. There is a procedure in the FSM to do so.
__________________
Retro!
Hater
accordztech is offline   Reply With Quote
Old 07-08-2013, 01:16 AM   #23
Accord problems
Contributing Member
Location: THE HIPPIE STATE WHERE EVERY ONE DRIVE A PRIUS... NORTHERN CALIFORNIA *facepalm*
Accord problems is cool... so far.
yes it does matter . if it just crank's tell the battery is died then that would not be a bad alt . get what im trying say now. if it was a charge issue the car would start right . then it would die after a smell amount of time .
op when it does this do you need the charger the first time or will it crank on it's own till the battery is died ?
Accord problems is offline   Reply With Quote
Old 07-08-2013, 06:44 PM   #24
indoplasm
Newcomer
No it will crank on its own till the battery dies then i have to recharge it
Old 07-08-2013, 06:45 PM   #25
indoplasm
Newcomer
And it will start and run till the battery dies
Old 07-08-2013, 11:54 PM   #26
Accord problems
Contributing Member
then you have a short simple as that. time to start tracing down wires to fiend the short . is it a intermittent start or as long as you keep the charger on it will it start every time ? does it die with the charger on ?
Old 07-08-2013, 11:57 PM   #27
accordztech
CB7tuner Member
I didn't realize it was the OP's response. I thought it was a question that someone else asked.
__________________
Retro!
Hater
Old 07-09-2013, 01:40 PM   #28
indoplasm
Newcomer
It will start everytime as long as i charge it doesn't die when i have a good charger on it but my charger is a 1.5 amp per hour charger
Old 07-09-2013, 01:47 PM   #29
wildBill83
CB7tuner Member
wildBill83 seems to have made some friends!
Try bypassing the ELD.
wildBill83 is offline   Reply With Quote
Old 07-09-2013, 02:14 PM   #30
indoplasm
Newcomer
I have with the ignition wire at the alternator i have it wired to the acc on the radio because its a 12v wire that stops sending power when the ignition is off
Old 07-09-2013, 05:06 PM   #31
wildBill83
CB7tuner Member
Quote:
Errr ... What!?! Why is your radio wired directly to your alt? Or is your ignition wire from the ignition switch wired to the alt directly, what good would that do? How is any of that to help with your charging problem, unless that is how you caused your charging problem was by jacking with the factory wiring.
Why did you post but ignore my response about the ELD? Quick jacking with the factory wiring and fix it right. I'm not in the thread to tell you how to rig something to work.
Old 07-09-2013, 06:44 PM   #32
Accord problems
Contributing Member
wow put the wiring back the way it's suppose to be . that is probably what is causing it not to charge .
Old 07-09-2013, 07:53 PM   #33
accordztech
CB7tuner Member
So with this method does it work? Does it charge?
Follow the fsm and it will help you back trace the issue.
__________________
Retro!
Hater
Old 07-11-2013, 02:38 PM   #34
indoplasm
Newcomer
Yes it does work
Old 07-11-2013, 07:46 PM   #35
accordztech
CB7tuner Member
Cool So follow the fsm to fix it.
__________________
Retro!
Hater
Old 08-27-2013, 01:05 PM   #36
Joe_cb7
Newcomer
Joe_cb7 is cool... so far.
I have the same issue with my car ive had to replace my alternator four time in the past 6 months so ilat first i thought i was just getting bad alternators but after the second time i thought something was going on in the harness so i took out the harnness n i found that some one had messed with the harness splicing wires together with bare wires so ima hit the junk yard and get a different harness and im hoping this fixes iy and my ignition switch just went out so im wondering if the switch had anything to do with it also...help would be appreciated n i hope this helps you out
Joe_cb7 is offline   Reply With Quote
Tags
alternator , charging , failure
