Old 04-03-2014, 08:20 AM   #1
Ender_Stiles
Newcomer
Ender_Stiles is cool... so far.
Alternator removal/installation procedure
So my alternator died on my way to an appointment this morning and I don't have the money to have a shop do it. What would be the correct/easiest way to remove and install the alternator and what tools would it require?
It's currently my household's only transportation so I need to do this as quickly and painlessly as possible.
Ender_Stiles is offline   Reply With Quote
Old 04-03-2014, 11:23 AM   #2
SlimmTex
CB7tuner Member
SlimmTex seems to have made some friends! SlimmTex seems to have made some friends!
Unbolt the power steering pump and set it to the side. (leave the hoses attached)
Disconnect the wires from the alternator.
Unbolt the alternator.
Installation is reverse of removal.
__________________
SlimmTex is offline   Reply With Quote
Old 04-03-2014, 12:40 PM   #3
mtnbikaah
Contributing Member
mtnbikaah is cool... so far.
Disconnect the battery first!! Very crucial.
__________________
Quote:
Originally Posted by deevergote View Post
mtnbikaah is offline   Reply With Quote
Old 04-03-2014, 05:58 PM   #4
Stoner51
CB7tuner Member
Stoner51 seems to have made some friends!
Disconnect the negative battery cable.
I got to mine without removing the power steering pump. I left the pump and PS belt connected and moved the Cruise control stuff out of the way.
You need a 14mm socket with a 3 inch ext and a 12 mm socket with the shortest extension they have. And a 10mm (I use a 1/4 drive for the alt power cable) and a long 10 inch extension with a swivel adapter to adjust the belt tension.
Just did this yesterday.
steve
__________________
Stoner51 is offline   Reply With Quote
Old 04-03-2014, 06:46 PM   #5
cb7 calling
CB7tuner Member
cb7 calling is cool... so far.
With medium depth sockets you can leave the cruise stuff. You will have to remove the p/s belt if you are changing the alt belt. As Steve said the pump can stay.If you have ac it's all tight but not impossible.
__________________
......father in law has it back again. Time to shine
cb7 calling is offline   Reply With Quote
Old 04-03-2014, 08:54 PM   #6
Ender_Stiles
Newcomer
I just finished and I must have spent an hour and a half just trying to fit the alternator belt on the freakin crank pulley. All is set and done though, all that is left is to jump start the car in the morning.
I managed with a ratchet, some short and some deep sockets and a pair of pliers. I'm definitely buying my own pair of pliers tomorrow though, I've had more uses for them the last few days than ever.
Old 04-03-2014, 08:57 PM   #7
bobbycos
Contributing Member
bobbycos seems to have made some friends! bobbycos seems to have made some friends!
Send a message via AIM to bobbycos
can you charge up the battery instead of jump starting it, that will prevent any possible voltage spikes which might damage your new alternator
bobbycos is offline   Reply With Quote
Tags
alternator , bad alternator , belts too , diy
