My player used to work without any problems... till one day when the noice stopped coming out of the speaker. the player still turns on except music coming out. i plugged the stock player and it works. my pioneer doesnt when i used it only sometimes but hardly. i tried a good working one from my moms car and still no luck. wires were all hooked up correctly. would it work wonders if i just direct the wires from the player to the stock harness from the car?
Player?
Originally posted by JDM_Certified View PostMy player used to work without any problems... till one day when the noice stopped coming out of the speaker. the player still turns on except music coming out. i plugged the stock player and it works. my pioneer doesnt when i used it only sometimes but hardly. i tried a good working one from my moms car and still no luck. wires were all hooked up correctly. would it work wonders if i just direct the wires from the player to the stock harness from the car?
Did you crimp the harness in or did you use tape?
Originally posted by pebojelly View Postif your Mom's car and yours share the same radio and hers works in her car and yours works in her car,yet both do not in your car.Your answering your own question.It's your car.I would check the sub harness for a loose wire.
Originally posted by bobbycos View Postget a new player
Originally posted by 604CB7 View PostMake sure the grounding wires are good... and see if the fuses are not blown... just sounds like something electrical is wrong... work your way back from the head unit and I'm sure you'll figure it out... best of luck
any technician's on here know if directing the player harness to the main harness, (cut and tape) would bring the sound back from the speaker? since it always acts weird when i plug it with the sub harness.
