My car just faild on me in the middle of a hill going up lol my speedometerwent crazy first then the lights went down aswell after a min.. or two it stopped and the whole car went black no lights or nothing. Could it be my alternator or my cables in the battery are supper fat and dont fit the termanols and it has a short thats why i think is that aswell. Need help ima change alternator i just want to know if you guys had a same issue or simolir?
alternator or battery terminals cables or what?
Originally posted by sonikaccord View PostIt's probably a ground. A short would blow fuses or set your car on fire, typically. clean your connections and try again.
Originally posted by cb7TwitchBoy View PostThe thing is they are clean its just the grown has two cables and they are thick and dont fit the terminals would that be the problem they dont go fully in some wires are sticking out i tried looking for bigger terminals but i cant find a that much of thickness.
Originally posted by F22Chris View PostDude, there's screws that tighten the terminals down. Take off the nut, and put it in between where the terminal and nut go.
Unless I misunderstood the question, then it's the same process for whatever you're trying to ground.
