wide band and gauge choices
    which wideband gauges are being run by other members?
    im looking at this,
    Innovate MTX-L Digital Wideband WBO2 Air Fuel Ratio AFR Gauge Kit 3844,
    or this,
    PLX Wideband O2 Air Fuel Ratio SM-AFR DM-6 Multi Gauge Touch Screen Gen 3 Kit,
    any suggestions?
    CB7TUNER.com
    Educating each other one car at a time.
    I will be using the AEM Wideband. Seems to be a standard unit to use across the board. http://www.summitracing.com/parts/avm-30-4100
      This is what I have been running for the past year. No issues.
      -1993 Accord EX SOLD
      -2012 GMC Canyon V8 4x4
        I guess I'll chime in for the innovative I have the lc-1 I've had it for a year or so and no problems.
        I don't know about the AEM but my problem with the innovative is the big controller that yku have to mount in the engine bay. The newer lc-2 allows you to mount it in the cabin with a long extension cable
        Steve
          Steve
          X2, I ran the LC-1 (without a gauge) for quite a few years with no issues.
          I mounted my controller next to the ecu and installed the O2 sensor near the flexi (though that was on a turbo application) Thats likely too far away to get hot enough NA.
          My 5.7 LS1 Holden Ute
            X3 I have installed and run 3 Innovate wideband products without issues and they are great for tuning N/A and FI with great accuracy for the price.
            Will be installing an LC-2 and G5 guage in the Tribute in the next couple weeks. I'm sure it will not disappoint!
            MR Thread
            GhostAccord 2.4L Blog
            by Chappy, on Flickr
              Ive been using the aem wideband for about 2 years now. Works great and fairly easy to install
                I've got a UEGO that works quite well for my usage.
                  I also have the aem wideband for a lil over a year now .. works great and no issues so far.
                  My Member Ride --> http://www.cb7tuner.com/vbb/showthre...66#post2857666
                  My For Sale Thread --> http://www.cb7tuner.com/vbb/showthread.php?t=181371
                    if your looking at the lc-2 you should check out the mtx, its there newest version, all integrated into the gauge with datalogging available through your laptop with logworks.
                    CB7TUNER.com
                      The MTX-L is a great all-in-one wideband product for AFR tuning for sure.
                      That being said, I have already purchased the LC-2 and a G5 gauge as I am also running an LMA-3 (Auxbox). The MXT-L is a wideband only setup. While the G5 is a configurable gauge. Once the AFR's are tuned you can use the gauge for monitoring other sensor data. Same reason I have the older XD-16 in my Accord. Great for tuning AFR, and then you push a button and you can read other sensor data.
                      MR Thread
                        tha'ts good information too know, also explains why it still cost the same or more than the mtx.
                        CB7TUNER.com
                          The mtx-l is incredible and very fast. Also very useful with software that allow for direct logging via USB
                          www.850fab.com
                          IG - @850Fab
                          FB - @850Fabrication
                            Im using the LC2 and the G2 gauge works great. Has been on car for about a half a year and no issues. Made my tuning easier.
                            http://www.cb7tuner.com/vbb/showthread.php?t=171625
                              I too use the AEM wideband. It used to be a bit more pricey although recently you can pick them up for about $170.
                              I have used an Autometer digital wideband and a Glowshit digital wideband. I did not like either. The Glowshit I strongly disliked.
                              IMO the AEM digital wideband is the best buy currently.
