great diy =] imma try this and send you a pik
INT: Painting your Cluster Bezel, Removing Trip *Pics* 56k =(
Did you have to remove the steering wheel or disconnect the battery like a half hour in advance?
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
Originally posted by beanzfynest617 View Postlooks real good ...
Originally posted by greencb7inkc View PostDid you have to remove the steering wheel or disconnect the battery like a half hour in advance?
you newer 9293 models the plastic trim around the key for ignition is in the way. so i take 3 screws out the bottom and the top piece comes out! and then you can remove the trim really! easy =]
on 9091 you can just slide the trim out.
Ride: 2002 Lexus IS300
Originally posted by cvc7chris View Postthanks
no the steering wheel and airbag stay where they are.
I painted my needles red, never thought of painting the bezel, but here a tip if you do end up taking off the needles which i did, all you have do is hook the gauge up, and turn the key to the second mark, and then take the needles and set them to the bottom of all gauges, but best to remember where your gas one is reading before taking it off so you don't end up running out gas somewhere, this is only if you plan on changing your cluster tho....
