I have my fog lights installed using the A/B/C harness and correct plug. They only work with headlights on. I have read on some of the threads that if you swap the #3 plug in the fuse box under the dash to the #2 spot this will allow you to turn them on anytime the car is on. I have done this and it is still only turning on when headlights are on . Does anyone have any suggestions or knowledge about this problem? Please help.
90 Fog light Wiring
The factory wiring allows for conformance to all state vehicle safety laws, not you flossing down the road when it's clear as the queen's diamonds outside. Many state laws dictate that for accessory lamps to be on, so too must the headlights be.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
http://www.cb7tuner.com/vbb/showthread.php?t=14345 .... someone had mentioned it in this part of the forum. I would have asked the question there but i am not allowed to at this time.
Originally posted by Jarrett View PostThe factory wiring allows for conformance to all state vehicle safety laws, not you flossing down the road when it's clear as the queen's diamonds outside. Many state laws dictate that for accessory lamps to be on, so too must the headlights be.
Read this http://www.cb7tuner.com/vbb/showthread.php?t=194053, I explain how the oem foglights are wired.
You can switch the primary relay's 12v headlight only input wire to an accessory source. Then remove one of the high beam cut relay's coil wires so it will not trigger. This will let you turn on fogs when key is on and lights off.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
Originally posted by lucifer1 View PostRead this http://www.cb7tuner.com/vbb/showthread.php?t=194053, I explain how the oem foglights are wired.
