Thread Tools Rating: Thread Rating: 10 votes, 4.50 average. Display Modes
Old 03-23-2018, 03:21 PM   #901
AccordWarrior
Guy Smiley
AccordWarrior is very helpful AccordWarrior is very helpful AccordWarrior is very helpful
Originally Posted by Mike1357 View Post
The trick is figuring out which brand braces to get. I won't knock ESP for rigidity, but it looks like tow hitch stock material. I've been trying to find a Cusco front strut bar for ages and I don't think a Neuspeed will fit over the H.
You're right...the Neuspeed won't fit with the H22. You could grind the VC on the H23 to make it work, but not the H22.
It's a shame, because the Neuspeed brace was fantastic.
AccordWarrior is offline   Reply With Quote
Old 03-24-2018, 07:53 AM   #902
Raf99
Ya, hook me up with a contact, I'm in Canada :P
Old 03-26-2018, 10:03 PM   #903
Mike1357
Mike1357 is cool... so far.
Welp, I decided to pick up an Ultra Racing front strut bar this weekend and I'm somewhat eager to see how I like it. I've only ever seen pictures of them so I might even do a product review thread on it to give others insight on it.
I'm torn between making my car a clean car with a stock hood and no flares, and making it a zany track style car. I certainly need to get on making a set of diy SI-T lights because I feel it will really tie in the rest of the front end together. I may unbolt the canards for a few days and see how I like it because that picture does look pretty slick.
Mike1357 is offline   Reply With Quote
Old 03-27-2018, 01:20 PM   #904
gloryaccordy
CBs are so cheap you could probably just buy another one to make a DD
Though I think I would like a CD for that... they are roomier and more refined
But I like the track look. I'd maybe get it wrapped in a different color like navy blue or British racing green
Old 03-27-2018, 03:12 PM   #905
Rilas
The Ultra Racing front bar is decent, but the ESP.net bar is, a massive improvement on the Ultra Racing bar, I've had both on Lola. Still though you made a good purchase Mike, you will notice the front stiffen up a bit.
Old 03-27-2018, 03:15 PM   #906
bseballkid1990
bseballkid1990 is cool... so far.
Mine is sitting in my living room waiting for me to install it. I cant wait.
bseballkid1990 is offline   Reply With Quote
Old 05-16-2018, 12:24 AM   #907
Mike1357
Well well, where to start. I recently moved about ten minutes from where I used to live so that put things on hold for a little while. I did end up installing the ultra racing bar and I was definitely happy with the improvements it made to the steering. After that everything kinda went downhill.
My car began to start overheating during stop and go traffic with my one radiator fan barely being able to keep up. I ended up scrounging up some universal electric fans from around the shop and soldered on some stock connectors. Somewhere in the process of doing that I damaged the wires going to my high pressure switch so I grabbed a pigtail from the junkyard to fix that. After fixing that I found out the system was severely undercharged. After leak testing the system, and passing (which means I have a super slow leak), I popped some more refrigerant into the system and it's blowing nice and cold once again.
The car was beginning to look really dingy at this point. Not having the time to wash it myself, I just decided to have it washed at work. That's where I screwed up. The detailer decided it would be a good idea to spray wheel acid on the barrels of my wheels to "shine them up". The clear started peeling off of all 4 wheels and, being that these are the nicest set of wheels I've ever had and they were in near mint condition, I was upset to say the least. Either there was acid residue in the soap bucket or he let the soap dry on the car, but now the paint is severely stained as well and the car just looks awful now. Not that it was particularly a great looking car before, but now it looks so much worse. I talked with my favorite local wheel repair shop and they say that they can't restore the wheels to the clear over polished lip finish so it looks like I'm stuck trying to figure out how to get the rest of the clear off and then polishing them from now on. All I've gotten is grief from the boss and a sorry from the detailer.
Thinking I was out of the woods after all that, I started smelling gas when I had the fresh air vent on. Turns out all the studs for the fuel rail had either snapped flush or came loose so my fuel rail was just kind of bobbling around in vaguely the right spot in the engine bay. I had heard mention from another member here that they had a similar thing happen to them. I'm not sure if the studs were over tightened long ago, if the vibrations from the solid mounts caused premature failure, or if the IACV bouncing around may have put stress on them. Regardless I had to panic and remove the intake manifold to get what was left of the studs out on a Friday. I still had my stock intake manifold so luckily I was able to steal the studs from that to gently reinstall in the skunk2 with some lock tight. I was able to find some silicone vacuum tubing so I moved the IACV down by the steering rack to get it out of the way. If there was a silver lining to this, it was that I did get the chance to see if my ITB setup would clear the brake booster (it does). Got that all back together and my throttle jammed open on the test drive which scared the ever living hell out of me. Turns out a small piece of plastic had broken off the inside of the throttle position sensor and me uninstalling the throttle body allowed it to move around into the danger zone (heh). Had a spare TPS on my old skunk2 throttle body but, being that my current throttle body is what I imagine to be a cheap knock off, the TPS wouldn't adjust out properly. She's still my daily driver so I just slapped it back together to get me home.
Today was the day I damn near lost my mind with the surging idle so it was time to rig it up. I ended up cutting part of a vacuum T fitting to slide over the sensor stud to compensate for the sensor not adjusting properly and now it reads almost perfectly within specs. While I was doing all this, I decided to fix the deformed butterfly plate the throttle body had (I picked it up used from a friend when I was in a pinch). I had noticed that a VQ35 throttle body had almost the same size butterfly plate as a generic 70mm honda throttle body. No time to measure, only time for action. VQ throttle bodies are notorious for going bad so we had a bunch sitting in a core pile at work. I drilled out the screws that held the plate in, drilled new holes to match my plates mount points, and bolted it in place. It's all back together and running and idling better than it has in the past 4 years.
Did I mention my inner taillight decided to desintegrate and my drivers window regulator is throwing a fit? Somewhere in there I managed to pick up the wagon trunk floor bits from the junkyard and install them, which I must say was a pretty decent mod.
So now you are all caught up.
Old 05-16-2018, 06:18 AM   #908
Jarrett
So is that where the story ends with the detailer? Nothing is going to be done?
Old 05-16-2018, 08:55 PM   #909
Mike1357
My boss had offered to have them re-cleared in house, but that means I would need to take my other set of wheels back off my girlfriend's car and put new tires on her stock wheels.
Old 05-17-2018, 05:14 AM   #910
Raf99
wow. I mean it can all be fixed, but wow. It would still take some considerable downtime for the wheels to be fixed and the cars paint too.
That sucks...
As for the fuel raid studs breaking, can't say I've ever heard of that.
Old 05-23-2018, 10:38 PM   #911
Mike1357
Yeah, the down time is the kicker. It would be one thing if I had a garage and this wasn't my only car, but it's my only means of transportation. I probably shouldn't daily a project, but I feel I wouldn't enjoy it as much if I didn't.
I think it was losiracer that had an issue with his fuel rail studs or nuts loosening. I didn't think anything of it at the time but I probably should have.
After looking at that picture with the hood vent missing and no canards, I decided to pull the canards off and I'm thinking of picking up a carbon hood from a friend.
Old 05-24-2018, 02:49 PM   #912
marcusv8thunder
marcusv8thunder is cool... so far.
I feel you on the idle hunting. I neally went mad trying to find mine. I went everywhere, tried everything, then it turned out to be a simple issue in the end. The PCV valve.
UKDM 93 CB3 Page (1) H22A U2Q7 LSD
UKDM 91 4ws Page (3) OEM Minter
NOW H22A U2Q7 SWAPPED
marcusv8thunder is offline   Reply With Quote
Old 06-01-2018, 11:28 PM   #913
dhill_cb7
dhill_cb7 seems to have made some friends! dhill_cb7 seems to have made some friends!
Mike read through your thread and this last page made me really feelvfor you. Wish you were close so I could help. Not sure how much I could do but I presume it is better than nothing.
Sometimes when stuff goes wrong we are tested and I think you sticking with it shows the dedication. Keep up the amazing work. Can't believe the acid damage man...
dhill_cb7 is offline   Reply With Quote
Old 06-04-2018, 10:01 PM   #914
Mike1357
Marcus, the hunting idle is such a pain because it could be so many different things. To be honest that's kind of why I like OBD2 cars.
Dhill, thanks for taking the time to read thru it! I appreciate your offer for help. Unfortunately I had a bit more bad luck with a taillight I purchased from another member getting crushed into pieces in the mail. At least mechanically the car is sound for now.
Old 07-15-2018, 01:20 PM   #915
Mike1357
Well, thanks to a very close friend of mine, I now have a carbon hood back on the CB. Ironically enough I was given this hood from the same individual I picked up my first carbon hood from around 8 or so years ago (Juice21). About 7 years ago to the day was when I messed up my first carbon hood in an accident. I have to say thanks to Raf for posting that picture that made me want to go this way with the car. I also have a GTS bug guard that I'm thinking of putting on the car this weekend to give the hood just that little bit more protection. I am almost certainly going to try and pick up a carbon version of the JL grille now to compliment the hood.
Old 07-16-2018, 07:44 AM   #916
Grumpys93
Looking good Mike!
~Nick~
Old 07-16-2018, 12:30 PM   #917
NH-503P-3
NH-503P-3 is cool... so far.
That hood is a very nice addition. Great score Mike. The bug guard wouldn’t be bad either. I’m thinking of getting one here soon.
~Mark~
Old 02-06-2019, 10:57 PM   #918
Mike1357
Thank you very much guys. I did run the bug guard for a little bit but I just didn't like the way it flowed with the rest of the front end.
A few months ago I had my fuel rail bolts snap for a third time. At this point I've gotten pretty good at taking out what's left, but it's quite inconvenient. I ended up getting some class 10.8 bolts from a local supply shop and added some fender washers under the plastic rail supports to try and spread the load out more evenly. For some reason when they made the rail stands for the intake manifold, it's like the casting for the posts were too far forward so the bolt holes are very far back on the posts and not centered like they probably should be.
Today I was able to finally purchase a new clutch and flywheel setup. I've been nursing a slipping clutch since September so I'm really looking forward to being able to drive with some spirit again. I decided on a stage 1 ACT clutch with a heavy duty pressure plate and a 12lb ACT steel flywheel. I chose a full faced clutch simply because speed bumps and stop and go traffic are something I still deal with daily and I need to be able to slip the clutch just a bit more than I can now with my 4 puck. The heavy duty pressure plate supposedly gives me a torque capacity somewhere around 270ft/lbs so if I ever do find a supercharger kit within my budget, I won't need to buy another clutch kit. I've been toying around with the idea of a lightweight flywheel for a long time but usually shied away from them because of what I would read about them. After driving a few cars with lightweight flywheels, I'm confident that I'll enjoy the response enough to outweigh the cons.
The car definitely needs a bit of maintenance. Currently I need to replace both axles, replace the leaky oil cooler o-ring, replace both rear upper balljoints (SPC maybe?), and possibly replace the rear calipers as well. Ultimately the coilovers are done for too, but that will have to wait for later in the year.
Old 03-08-2019, 08:13 PM   #919
Grumpys93
How’s the car Mike? Did you get to fix a couple of the issues?
~Nick~
