Old 06-02-2018, 01:07 AM   #1
laloquera
laloquera is cool... so far.
Car wont start
Car died on my at Costco gas pump, had to push it off the island. Tried to trouble shoot on the spot with no idea. I have power to my car when I turn the key to II key position: radio work, power antenna, and windows. I try to turn the key to start and nothing, not a noise. I broke out my testing light and multi meter, 14v on the battery. Tested my coil tower with a testing light and nothing when I turn the key on. Check my Main Relay, and my Computer, and fusses. Also double check my starter wiring, looks good. I tried everything I know on the spot. I'm clueless. Anyone have any ideas on what else can it be.
Thanks
PS
Im having my car towe home tomorrow morning.
laloquera is offline   Reply With Quote
Old 06-02-2018, 01:17 AM   #2
zedjr10
zedjr10 may have said something they shouldn't have...
Thanks
PS
Sounds like a starter solenoid unless you mean actually it died pulling in station. When does that ever happen. But i bet u mean u couldn't restart after turning it off and starter wouldn't turn over. Or your ignition went bad and wouldn't turn over starter. I had same thing after car was stolen happen to my ignition system. Just wouldn't work right.
Old 06-02-2018, 11:36 AM   #3
laloquera
No error codes, gonna go towe the car. There go's my weekend
Old 06-02-2018, 01:20 PM   #4
laloquera
Just got home and had towed. I have a no crank situation here. Any stickies, vids or best of ideas as to where and how to get started are welcome. I have a testing light and multi meter. Im betting its a short some where.
I will get started but will be checking in all day long.
Thanks
Old 06-02-2018, 05:03 PM   #5
laloquera
ok, making progress here. Took a hammer and tap on the starter and solenoid and it started. Gonna swap out the starter and see how it go's.
Old 06-02-2018, 05:52 PM   #6
fleetw00d
Did you check that the connections were tight first? I actually had one where the starter was loose on the transmission.
Old 06-02-2018, 08:13 PM   #7
laloquera
just had my starter bench tested at Autozone, it pass with flying colors. I did notice the bottom 14mm bolt was loose as a goose. Should I slap it back on and tightened them bolts up? Im debating it.
Old 06-02-2018, 08:36 PM   #8
F22Chris
Is your car a manual or automatic?
Old 06-02-2018, 11:32 PM   #9
laloquera
Automatic. Well I slap the starter back on, no issues yet. I guess the starter is grounded by those two bolts. Anyone have a better clarification?
Thaks
Old 06-03-2018, 10:55 AM   #10
Raf99
Thaks
Yep, you found your problem. Loose connection to the starter. Starter is grounded via itself to the block, the one wire is the start power wire.
Edit: And be careful with the starter power wire. If you touch it and a ground on the car (almost any part of the car) you will get a shock. You would be grounding the positive. If working on the starter disconnect the battery first.
Old 06-04-2018, 08:00 PM   #11
laloquera
Crap, Im back! My starter went out again today had to tap a few times to get it started. Though I tested good at Autozone last Sat, it had a slight rattle sound inside. Anyways I have to get another one.
Also. I tested my alternator, It tested at 14 volz, that's slightly low as the recommended minimum 14.2 Voltz. Are these two issues related or separate?
Thanks
Old 06-04-2018, 08:07 PM   #12
F22Chris
Completely separate. 14v is technically within spec so that’s fine. Tapping on the starter and having it work usually means it’s failing and needs an r&r.
Check to see if it’s loose again, and make sure your transmission/bolt threads aren’t stripped.
Old 06-04-2018, 10:38 PM   #13
laloquera
Im swapping both out just to play it safe.
Thanks
Old 06-06-2018, 09:47 PM   #14
laloquera
Anyone know the acceptable range for voltage output on our Denson Alternators? Thanks.
Old 06-06-2018, 10:22 PM   #15
F22Chris
Acceptable charging voltage is 13.5-15v depending on the vehicle. For the CB it says it should be around 14.3v.
Alternator is starter aren’t related though. An alternator charging at 14v is perfectly fine. Check the resistance in your power wire from the alternator to the battery.
Old 06-12-2018, 01:17 PM   #16
zedjr10
12.2 to 14.5 i believe.
Old 06-13-2018, 07:20 PM   #17
laloquera
Nailed it, swap out the starter. Alternator check out with my multi meter. Thanks to those folks who gave input and help.
Old 07-07-2018, 10:32 PM   #18
F22Chris
12.2 is way too low. A fully charged battery is 12.6v. 12.2v will never charge the battery fully.
There are 6 cells in our standard 12v battery which give out 2.1v each. If your battery is giving readings under 12.4v do a load test.
An alternator charging at 13.5-15v is considered within the universal spec.
Again, the ideal range is around 14.3v under load for the CB7. That means with your high beams, wipers, blower, radio, defroster (anything that creates a load, turn it on). If your alternator is putting out around 14v, odds are you’re good to go.
