Thread Tools Rating: Thread Rating: 9 votes, 4.56 average. Display Modes
Old 01-28-2018, 10:34 PM   #361
Jarrett
Nice purchase! Those injectors are the newest revision of the Bosch EV14 format and are supposed to be a lot more stable than the outgoing ID1000s, which were already renowned for how good they were.
If you see any threads or posts of mine whose picture links are broken (there are a lot), please send me a link to the thread. I will gladly fix them. I don't see it as a fruitless burden. This site has helped give me quite a bit of my drive and passion for cars, and fixing my picture links is the least I can do to give back.
Old 01-29-2018, 08:45 AM   #362
NH-503P-3
NH-503P-3 is cool... so far.
Hey Nick are those the stock internals in that f22a block?
Old 01-29-2018, 09:38 AM   #363
Rilas
Things are looking great Nick! Can't wait to see this engine back together and hauling the Accord around.
Old 01-29-2018, 10:50 AM   #364
Bunta
Bunta is cool... so far.
Have you fixed the coolant leak issue yet? I had the same issue in the exact same area and it turned out the valve itself had developed a crack, just a heads up if you get the proper hose and still have issues.
Old 01-29-2018, 12:31 PM   #365
Grumpys93
Negative, the pistons are wiesco, Bisimoto h-beam rods, arp rod bolts, acl bearings, KS tuned balance shaft elimination kit, rebuilt OEM pump, micropolished crankshaft. Most of the first page is up to date. Except the head components.
Thanks Will, I’m starting to get that Christmas Eve feeling.
Yes, first it was a small rip in the hose and then it was the clamp was not fully seated. I thought about the valve so I turned the heat knob to cool to see if it stopped it and it didn’t.
~Nick~
Old 01-29-2018, 01:27 PM   #366
NH-503P-3
Damn thatís nice. I might have to duplicate your bottom end applications. Iíll hit you up later today on more info.
Old 01-29-2018, 06:57 PM   #367
Grumpys93
Damn that’s nice. I might have to duplicate your bottom end applications. I’ll hit you up later today on more info.
Sounds good Mark. Happy to share my set-up and my learnings on the way.
~Nick~
Old 02-04-2018, 12:50 PM   #368
Grumpys93
Got some more goodies in the mail this week:
TurboSmart Mechanical Boost gauge:
Boost Labs V band Flange and adaptor for borg warner turbo to downpipe:
Then finally got the head back from the machine shop, looks great and am happy with the price and work that was done:
I didn't waste time and got the head installed on the block and the valvetrain and the delta camshaft installed (Bisimoto Pro springs look great):
I'm happy to finally see this coming together, but the money pot is running low again, so this build will slow down unfortunately. I will be receiving more parts this week and will update with more pics and info as it moves forward.
~Nick~
Old 02-05-2018, 10:23 PM   #369
Mike1357
Mike1357 is cool... so far.
This is turning out to be so damn awesome. The hood pins look like they turned out great and the grille really finishes it off well. The steering wheel is a cool addition and even better that your wife got it for you. I've always like the way those civic wheels look on our cars. Two thumbs up dude.
Mike1357 is offline   Reply With Quote
Old 02-06-2018, 06:27 PM   #370
Grumpys93
Thanks Mike greatly appreciated!
~Nick~
Old 02-06-2018, 09:51 PM   #371
Grumpys93
Today I received the back plate for the lower timing gear, so when the little one went to bed I got to work.
Installed the backing plate, lower timing gear and lined up all the TDC marking on the lower timing gear and the cam gear. I then installed the OEM Timing belt which was a lot easier then the blue gates on the F22B:
Then adjusted the valves to Delta Camshaft specs: Intake: .006 and Exhaust .008: This was tedious but glad to see that I was able to get them within specs.
Then installed the lower timing cover, the alternator belt and crank pulley chewed this up pretty good, I wish the crank pulleys weren't a pita to pull or I would pull one in the PAP.
There is still a lot to due and I'm about to get to the point where I will have to pull the h22 and start removing the parts I used on it that were suppose to be for the f22a.
But I received more parts today nothing to special just the fittings for the oil feed and oil return for the turbo: got these from fab boys on ebay and the product looks great:
Stay tuned more parts are still to come in.
~Nick~
Old 02-07-2018, 08:21 PM   #372
NH-503P-3
Lookin real nice Nick.
Old 02-09-2018, 07:18 PM   #373
Grumpys93
Thanks Mark!
So went out and bought some things needed, new thermostat one that opens at 170F and 8 things of spark plugs. Hopefully that is enough but we shall see. Went with John Vega's recommendation of going two steps colder.
Then got some more parts in the mail, Frank at Treadstone performance gave me a great deal on the rest of my oil line kit that I needed as well as the intercooler piping, couplers, and t-clamps. He also threw in a t-shirt for free! Great customer service and will do business with them again:
Here is the rest of my oil feed line I needed, according to Borg Warner they recommend a -4an fitting and no need to run an oil restrictor:
Also purchased a T3 to T4 adapter since the Borg Warner is a T4 housing and my previous manifold is a T3. I will eventually upgrade to a custom manifold that is divided with dual wastegates, but for now this will do.
The last pieces of my build should hopefully be coming in next week, however I will be in DFW, TX for some training.
I haven't decided yet on when I want to park the Accord and start taking out the h22. I still haven't hit 500 miles on it with the stage 4 clutch, but I did do what I previously did with my ACT stage 3 and do a couple low rpm dumps and high rpm dumps (which ACT at the time recommended on breaking in a new clutch). But I still think I want to get to at least put 500 miles on the clutch and flywheel before I pull the h22.
Can anyone recommend any breaking in oil? I am getting pretty excited to have this installed but like I mentioned earlier, my money pot is running low and I am expecting the tune to cost around $600. So I may wait until I have that chunk of change in my bank account before I install the built motor.
Decisions, decisions, decisions....
~Nick~
Old 03-10-2018, 03:39 PM   #374
HenRoc
Black Thunder
HenRoc seems to have made some friends! HenRoc seems to have made some friends!
Send a message via AIM to HenRoc
Where'd he go?
Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
HenRoc is offline   Reply With Quote
Old 03-10-2018, 04:29 PM   #375
Rilas
Nick isn't gone. He just got a 7 day temporary ban. Unfortunately though, he is being sent out for training before the 7 days is over. So no updates on the car before he gets sent off again.
Old 05-13-2018, 02:21 PM   #376
Grumpys93
Hey Guys just checking in, I am about a month out from graduating from Officer Candidate School, where I will then be moving to Pensacola. So progress on this will continue to be slow. But I will slowly chip away at it.
As for the motor, it is ready to be dropped in and I have the money for a tune and all the other things I have planned, but because I will have to move within 10-15 days after graduating Officer school, I won't have time to do the swap how I want to. So I am hoping by the end of the year this car will be force fed again.
~Nick~
Old 05-13-2018, 05:06 PM   #377
NH-503P-3
Right on Nick. Good luck with the rest of your schooling and the move.
5 studded & leather clad-Praise The Lowered
~Mark~
Old 05-14-2018, 11:46 AM   #378
timmy0tool
Accord of the Month: April 2006
timmy0tool is cool... so far.
Send a message via AIM to timmy0tool
life is more important and early congrats on getting your schooling done!
the car will always be there so you can enjoy it at your own leisure, don't skimp on the rest of life.
there is so much more to live for than just our little hobby...and this is coming for a diehard CB guy!
what a great build here!
1cor10:31
- 92 LX coupe
- 96 EX wagon (sold)
timmy0tool is offline   Reply With Quote
Old 05-23-2018, 09:30 AM   #379
Rilas
Nick, glad to hear that training is going well. Hopefully even after moving you can get to working on the Accord again at some point.
Old 06-19-2018, 09:43 PM   #380
Grumpys93
So finally back in Jax and I will actually be here for 2 months before heading to Pensacola. Decided to take her for a spin and was greeted with a dead battery even though it was connected to a trickle charger. The battery was over 5 years old so I think the battery just pooped out of me, so 140 dollars later got a new battery and she runs like before.
I do have an issue right now with every time I press the brake pedal my dash lights come on, after reading some forums I think I may have placed the wrong type of bulb in. But I will double check later this week.
For my birthday my wife bought me a Blox weighed Sphere shift knob and my sister got me a duel pressure gauge for the fuel rail so I am pretty excited about throwing those parts in. Iíll post pics later. I am really hoping Jon comes back and makes the cb7 knobs, but this one will do for now.
~Nick~
