oneoffaccord : 1992 Accord EX (2)
    Originally posted by SilkyCB View Post
    So is the only reason for the RSX master/booster for looks?
    1) its different
    2) its more compact
    3) it looks better
    4) its not old
    5) cant think of a 5th answer
      Well I got my chassis harness all done. Completely eliminated the automatic transmission, cruise control, abs, a/c wiring. Routed the engine wire harness where I wanted it (they all come out together thru the middle of the car). I'm pretty sure I probably missed some wiring for the transmission wiring that goes to the dash but oh well lol. Next is to put the harness in the car and route the engine and headlights where they have to go and its a done deal.
        This looks intense. Keep up the work, sounds like an interesting project.
          Took the dash out from downstairs. plugged the dash into the fuse box and the chassis harness. Plugged the center and fuel pump harness into the chassis harness. Pretty much made sure everything went were is was suppose to be. I gotta get the chassis harness put into the car next then I can finish up the headlight tuck.
              Excited to see this start coming together
                thanks man I'm highly excited aswell
                  man i wanted to do this to my car but i dont have the room to take it that far down
                    what do you wanna do to it?
                      Here's a lil update, I had these strobe lights for years. Legit for years, the box was dusty as hell. I will be installing these in the bumper lights. Also do a separate harness for the speedometer, knock sensor, vtec solenoid and pressure switch.
                        What master cylinder is that, the S2K?
                          Brake master cylinder?
                            Sorry the clutch. I know the brake is the RSX.
                              clutch is S2000
                                Going to have some updates tomorrow, gotta upload a bunch of photos.
