Old 10-06-2010, 01:09 AM   #1
laloquera
CB7tuner Member
laloquera is cool... so far.
Failed CA Smog
k, Im gonna repost my numbers. Did CA change their emissions standards? I put alot work into my CB7, shes my baby. It ticks me off, when some cheeze dick tells me Im a gross polutor.
CO2 O2
Test RPM MEAS MEAS
15mph 1834 14.8 0.2
25mph 2528 14.9 0.2
HC (PPM)
Test RPM MAX AVG MEAS
15mph 81 27 36
25mph 91 21 18
CO
15mph 0.74 0.16 0.02 0.32
25mph 0.62 0.11 0.03 0.04
NO (PPM)
15mph 554 270 688
25mph 511 207 502
15mph FAIL
25mph PASS
Hope Im not missing any digits. Thanx
laloquera is offline   Reply With Quote
Old 10-06-2010, 01:38 AM   #2
ExplodingCake
Noob Herder
ExplodingCake seems to have made some friends! ExplodingCake seems to have made some friends!
Clean your EGR valve and ports.
__________________
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
ExplodingCake is offline   Reply With Quote
Old 10-06-2010, 10:49 AM   #3
laloquera
CB7tuner Member
I did that like three years ago, but Im willing to clean them agian. How do I get the cup plugs off, the ones the stealership gives you. I took off the original ones off.
Old 10-06-2010, 01:32 PM   #4
H.M.
CB7tuner Member
H.M. is cool... so far.
You'll have to drill the cups and use a slide hammer to yank them out. Then replace with new stealership cups.
__________________
90 Accord Ex, F22A4. Slight fire damage.
H.M. is offline   Reply With Quote
Old 10-06-2010, 08:57 PM   #5
laloquera
CB7tuner Member
Kewel, sounds like found. Especially if you alredy done the job before. Im gonna double check my EGR valve for succion. I think I swap out my cat three years ago, thatsbull shit, im not forking out another $300 to have it replace. Thats crap, thats gonna be the last thing Im gonna try to switch out if it does not want to pass smog.
Old 10-08-2010, 11:37 AM   #6
apalileo
CB7tuner Member
apalileo is cool... so far.
how old is your o2 sensor? it could be showing signs of innaccuracy if it's been some time.
apalileo is offline   Reply With Quote
Old 10-09-2010, 02:43 PM   #7
laloquera
CB7tuner Member
Failed a 2nd time. Though my numbers improved my nox# were still high 658 and the max is 554.
I pulled the egr plugs and valve, sprayed the crap out of it, complete tune up and I still failed.
I purchased a vacum pum to check egr suction, but Im gonna need a procedure or write up, if anyone has one.
So here are my new numbers:
CO2 O2
Test RPM MEAS MEAS
15mph 1842 14.9 0.2
25mph 2562 15.0 0.1
HC (PPM)
15mph 81 27 37
25mph 91 21 21
CO
15mph 0.74 0.16 0.29
25mph 0.62 0.11 0.06
NO (PPM)
15mph 554 270 658 (before it was 688)
25mph 511 207 497
15mph FAIL
25mph PASS
Old 10-09-2010, 04:14 PM   #8
91cblx
CB7tuner Member
91cblx is cool... so far.
Send a message via AIM to 91cblx
CO2 O2
Test RPM MEAS MEAS
15mph 1842 14.9 0.2
25mph 2562 15.0 0.1
HC (PPM)
15mph 81 27 37
25mph 91 21 21
CO
NO (PPM)
25mph 511 207 497
15mph FAIL
25mph PASS
I think they did change their emission standards in 09'. I'm in the same boat as you. fail the first time, cleaned out the egr, egr ports, failed again. Here is my smog thread http://www.cb7tuner.com/vbb/showthread.php?t=166216 CA smog. They said I need to replace my catalytic converter...again
91cblx is offline   Reply With Quote
Old 10-09-2010, 06:18 PM   #9
laloquera
CB7tuner Member
Crap! I just had a cat slapt on there two years ago. Its not rattleling, nothing. Im just tying to avoid buying a another cat. Am I gonna have to buy a cat avery other year as I smof it. Thats bull shit. Anyone else got feed back base off my numbers. Thank you.
Old 10-09-2010, 08:09 PM   #10
laloquera
CB7tuner Member
I just check my egr valve for leaks, it check out OK. Any other feed back?
Old 10-10-2010, 09:45 PM   #11
laloquera
CB7tuner Member
Swap out my evap purge solenoid, newone is not ticking. Also, one of the small hoses was leaking so I swap it out. I double check the rest of the hoses for leaks. Im pretty much gonna role into another smog station, not the same dude that failed me twice. Wish me luck & I will post up my results tomorrow.
Peace in da middle east my brothers
Old 10-10-2010, 09:57 PM   #12
wed3k
Contributing Member
wed3k seems to have made some friends! wed3k seems to have made some friends!
Send a message via AIM to wed3k
all stations are the same if youre going to a test only.
put vacuum to the egr when the engine is running and the car should stall, thats when you know the egr is doing something. plus you really need to clean that carbon out, not just spray some carb clean.
__________________
I <3 G60.
wed3k is offline   Reply With Quote
Old 10-13-2010, 10:10 PM   #13
laloquera
CB7tuner Member
Guess what? Nailed it, my car passed today doing 552 on the (NO), by a hair on my freaking chin chin. Thanks to all who gave a crap
I guess I had to go back and do my egr ports twice, get them completely clean, I mean really clean and use a high power vacuum to get everything out. Called my cuz out in Maui, he stated swap out my NGK Iridiums, they burn and run abit on the hot side. So I went out to WalMart & got the cheapest Autolite and roled up to the smog shop & Bingo. I hope what work for me, will work for others. Im back with my Iridiums.
Thanks agian
Old 10-13-2018, 01:49 PM   #14
laloquera
CB7tuner Member
I know this is an old post, but it actually the smog history for my car. This are my most recent numbers. Just did a short block swap a year ago with everything else being OEM transfer from one engine to the other.
CO2 O2
Test RPM MEAS MEAS
15mph 1825 13.7 2.0
25mph 1889 13.6 2.0
HC (PPM)
15mph 81 27 49
25mph 91 21 46
CO
15mph 0.74 0.16 0.22
25mph 0.62 0.11 0.28
NO (PPM)
15mph 554 270 994
25mph 511 207 892
15mph FAIL
25mph FAIL
Im gonna trouble shoot the basics and hopefully someone will gat back me with a more precise clarification. Have a happy wrenching Saturday folks.
Old 10-19-2018, 11:03 AM   #15
laloquera
CB7tuner Member
Hey folks. Just notice something today. Its getting cold here in the mornings in NoCal. I wanted to put the heater on and the air did not heat up through the vents. Both top and lower rad hoses felt pressure inflated, no leaks. My temp gauge held normal and fans came on when needed.
I know of CB7 having (3) temp sensors. Can one of the sensors be related with smoging and throwing my numbers off?
Old 10-19-2018, 08:00 PM   #16
F22Chris
CB7tuner Member
F22Chris is very helpful F22Chris is very helpful
Well NOx is there from higher exhaust temperatures. So make sure youíre cooling system is functioning cause thatís bad in itself. Make sure the EGR system is functioning. if that doesnít fix it, the catalyst may need replacement.
Youíre test is twice the max amount, so Iíd bet the cat is in need of replacement.
If you want, you can try an oil change, retard the timing, and clean your EGR valve & passages.
Remember if youíre lowering NOx, the others will rise.
__________________
F22Chris is offline   Reply With Quote
Old 10-21-2018, 10:14 PM   #17
wed3k
Contributing Member
you still have 2% o2 in your system. are there exhaust leaks before the cat? if not then the cat might not be efficient
__________________
I <3 G60.
Old 05-05-2019, 01:50 PM   #18
laloquera
CB7tuner Member
Im still dealing with this issue, paid my dmv fees back in November but have not taken it to get smog. I have been cited my my local parking enforcement with a fix tickets. The bastards.
Anyways, I have swap out my EGR Valve, tune up. Im researching my old post in here to try try to help my self deal with old issue that keeps popping every other year. Sucks!
Old 05-19-2019, 10:42 PM   #19
wed3k
Contributing Member
is there still o2 in the exhaust? those are potential exhaust leaks or the cat is too inefficient
__________________
I <3 G60.
