Closed Thread
Old 04-20-2010, 03:35 AM   #1
evil_demon_01
Moderator
evil_demon_01 is someone to admire evil_demon_01 is someone to admire evil_demon_01 is someone to admire evil_demon_01 is someone to admire
Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Welcome to the Beginner Technical Sub forum.
This Sub forum is the place to ask any questions regarding performance, maintenance, or repairs.
If you want to go fast, or just change a flat... this is the place to ask!
First things first, We assume ALL of you have read the rules.
If you make a thread / post that goes against the rules, it will be dealt with accordingly. The rules can be seen by clicking the link below.
CB7Tuner.com Forum rules, PLEASE READ AND UNDERSTAND HERE FIRST
Also:
Threads without descriptive titles will be deleted, this applies to ALL sections.
Most General Info / FAQ's can be found below.
For more detailed info, please check the "sticky" threads in the section most appropriate for your question. MANY things are so regularly covered on this forum that the necessary info has been compiled and presented in a clear and organized fashion. Asking a question that was previously covered in a "sticky" thread will very likely get you some rude replies.
Maintenance / Mechanical / Diagnostics / Safety:
DriverSide
Diagnostic Checks
Car Safety Checks
Torque Specs
Tune up Specs
Timing Belt procedure
Fluid Capacities
Sensor Locations
ABS error codes
VIDEOS showing common Honda maintenance and repair procedures
Fuel Efficiency Compilation
FAQ's:
H/F Series Engine Info
Erratic Idle fix
F/H Series Transaxle Info (Manual & Automatic)
How to make 30+hp for $500 or less... (DX/LX F22A1 only)
Engine Removal DIY
Frankenstein/Hybrid info
My 5.7 LS1 Holden Ute
evil_demon_01 is offline
Closed Thread
