This might sound a bit fucked up but... I just bought H23a DOHC head and dizzy. I already have the H23 intake manifold.
Guys in States and Europe put H23a heads on F22 85mm bore 8.8CR blocks with F23 headgasket. It's a pointless head swap cause of the low compression. It barely makes as much power with a good tune as a stock H23. Good for boost tho.
The F20A4 block has 85mm bore and 9.5:1 CR. The H23A head itself doesn't affect the compression in any way. My H23A head will get a nice mild shaving in our local engine shop, so the CR will be somewhere at ~9.7:1. Now you are asking yourself why I just don't put in a whole H23?
F-blocks have iron sleeves. If I want to go boost I don't have to get the block sleeved, so it'll save me some €€€. And I will go boost when I get this thing running properly. But at first N/A.
So the setup will be something like this:
-F20A4 block rebuild
-H23Ax DOHC head shaved and p&p
-F23 headgasket
-H23 timing belt
-H23 P14 crank gear
-H23 intake manifold
-H23 injectors
I might also do a P/S delete while I'm at it.
Oh, and I got the head and dizzy for 100€, wich is 112 bucks.
-F23 headgasket
-H23 timing belt
-H23 P14 crank gear
-H23 injectors
