Go Back   CB7Tuner Forums > Parts & Performance > Suspension > Brake Performance
Old 05-21-2015, 05:02 PM   #1
blackenwkn
CB7tuner Member
blackenwkn is cool... so far.
acura tl type s calipers
Ok so I can get them for a "steal" I was planning on using the ffc adapter but after re reading it, looks like it's for the rl and not the calipers I'm getting. I'm wondering if anyone has done it or if there's a write up I've missed?
Thanks!
blackenwkn is offline   Reply With Quote
Old 05-21-2015, 05:50 PM   #2
Jarrett
Contributing Member
I'm in the process of doing it now. I've mocked it up, but haven't actually put everything on the car. You need a whole lot more than just the calipers themselves. You need the knuckles, rotors, pads, lower ball joints, outer tie rod ends hard brakes line, soft lines and possibly more. You will also have to ream out the hole on the lower control arm to fit the larger-sized lower ball joint.
The other parts I may end up needing are upper control arms and axles. Those will only be discovered once I get everything up on the car and mounted. I told myself that I'm going to put the front suspension on that car as soon as I can because I want to trailer that car up here to my house in Denton. As soon as I do, you're welcome to come by and check it out. I'll warn you, though. It's not going to be cheap. If braking performance is your only goal, there are much better options. I'd be lying if I told you the "bling" effect didn't carry any weight with this.
__________________
My for sale thread with some pretty good buys in it.
http://www.cb7tuner.com/vbb/showthread.php?t=186737
2nd 1993 Accord EX frost white coupe
http://www.cb7tuner.com/vbb/showthread.php?t=205292
Old 05-25-2015, 03:44 PM   #3
blackenwkn
CB7tuner Member
Wow yea I'll probably be staying away from this project then, cudos to you for doing it though. The only reason I was looking into it was because I can get a set for $50 thought they mounted the same as the rls, but nope lol looks like I'll wait and try and find a set of rls.
Thanks for the info!
Old 05-25-2015, 05:19 PM   #4
Jarrett
Contributing Member
Does the person from whom you would be buying them from have the knuckles as well? I have a spare set of calipers and was going to do the same thing to my CL as well. If they have the knuckles, do you know if they would sell them?
__________________
Old 05-27-2015, 10:35 PM   #5
blackenwkn
CB7tuner Member
No strictly calipers, he bought a 240 and they were in the trunk lol added bonus
Old 07-05-2015, 03:58 PM   #6
oneoffaccord
Accord of the Month: November 2006
oneoffaccord seems to have made some friends! oneoffaccord seems to have made some friends!
Send a message via AIM to oneoffaccord
I just found a set of 04-08 TL-S front calipers as well, what is needed for the swap. Im doing 5lug so i already have crv front knuckles. I gotta do more research on these.
oneoffaccord is offline   Reply With Quote
Old 07-05-2015, 06:00 PM   #7
Jarrett
Contributing Member
Did you not read what I posted above about what's needed for the swap? You need a lot more than calipers and those knuckles won't do you any good.
__________________
Old 07-12-2015, 01:07 AM   #8
Frijoles
CB7tuner Member
Frijoles is cool... so far.
Just go with the RL calipers. I'm using those on my car and they work great.
Frijoles is offline   Reply With Quote
Old 09-03-2016, 06:01 AM   #9
CyborgGT
CB7tuner Member
CyborgGT is cool... so far.
Personally, I don't trust those aluminum adapter blocks for the RLs. I don't like the idea of two bolts occupying damn near the same space, especially when they're torqued into a relatively brittle metal.
Any progress, Jarrett?
http://www.rsxretrofits.com/brembo.html
Thinking of attempting this myself, at least getting the calipers and discs soon for my Ody knuckles and seeing how accurate this claim of 'any 5-lug Honda' is. If not, this swap has been done to death on RSXs (not using all that crap you're bothering with) and I do enough mountain driving with that car. I'd go for the TL-S MC and booster as well though.
__________________
Project CB9 AeroR start-up: ////////// Slowly but surely...
My Wheel Well
Old 09-03-2016, 12:00 PM   #10
sonikaccord
Contributing Member
sonikaccord is cool... so far.
I have the original RL adapters from NVA-AV6 and they are a different design than the FFC adapters. I agree about the little bit of aluminum separating the two bolts, but I'm sure the shear force to actually break the adapter would be way more than the force of braking. Especially in the radial direction.
__________________
sonikaccord is offline   Reply With Quote
Old 09-03-2016, 02:45 PM   #11
Jarrett
Contributing Member
I've had it installed on the CL for a while. I bought a second set of knuckles that I need to install on the CL so that I can take the nicely painted ones off and put them on the CB they were intended for.
If the retrofit method I'm using didn't gain me larger lower ball joints and massive outer tie rod ball joints, I would elect the spacers in a heart beat.
__________________
Old 09-04-2016, 12:26 PM   #12
CyborgGT
CB7tuner Member
With me looking at the RSX Retrofits solution, I just took my Ody hub into AutoZone. Told the guy about this mad Frankenstein I'm trying to pull off, and he let me test fit a TL-S rotor onto it (as well as an Ody rotor, just to compare). The TL-S rotor's top hat fits over the outside diameter of the hub (I was reading online that DC2 guys were having a problem with this), however a problem lies with the inner lower lip that the rotor centers itself on. Either the hub's lip has to be machined to a smaller diameter, or the TL-S's disc hub bore has to be machined larger. I think machining the hub lip is the wiser move in the long run; I don't ever plan on removing my 5-lug conversion, but discs will naturally come and go.
__________________
My Wheel Well
Old 09-04-2016, 02:30 PM   #13
'93CB7Ex
Gold Member
'93CB7Ex is cool... so far.
i have RL calipers on my cls6. best upgrade ever. i just picked up a 04 accord 6/6 and it needs them bad!
__________________
'93CB7Ex is offline   Reply With Quote
Old 01-25-2017, 05:54 PM   #14
willbill642
CB7tuner Member
willbill642 is cool... so far.
Quote:
Have you considered the DIY version where you drill the hub out? Linky
That's my plan, especially since I can get a set of calipers under $100 now.
willbill642 is offline   Reply With Quote
Old 01-26-2017, 12:03 AM   #15
Jarrett
Contributing Member
Technically it's the knuckle that you drill out, but yes, that method is more cost-effective. You don't gain the larger lower ball joints and tie rods ends, but it does mean you can perform everything without much more effort than a brake job and not need an alignment afterward.
__________________
Old 01-27-2017, 01:01 AM   #16
CyborgGT
CB7tuner Member
Why are you changing out ball joints? Are you wanting to use the entire TL knuckle? It's easier to either drill out the CB knuckle to accept the larger TL caliper bolts or put threaded inserts in the TL calipers to use the CB hardware. And if you use the inserts instead of drilling the knuckle, you can more easily revert back to stock should you ever decide to go with a different caliper.
__________________
My Wheel Well
Old 01-27-2017, 01:09 AM   #17
Jarrett
Contributing Member
Because when I was doing this a couple of years ago, I wanted to know what was different, and I looked at all the gains that could be had by swapping the knuckle. I ran into an issue with the TL outer tie rod ends (which are larger than the CB's) as they are too short and couldn't find an appropriate one that fit the bill. The best thing I could find was the MDX outer tie rod ends which were even bigger still. So I have a massive outer tie rod end which helps for steering wheel feel. Not to mention it should last much longer than the Accord-sized unit would take under heavy abuse. I also gained larger lower ball joints and much beefier wheel bearings.
If you're only doing this job to say you have Brembo brakes, then go ahead and use the spacers and drill holes. It's much cheaper and cost-effective. But in my case, I built it in my head first, to see what I would gain and the compromises I would have to make. Ultimately I decided those benefits outweighed the meager cost to buy 4 knuckles (2 for the Accord and 2 for the CL).
__________________
Old 01-27-2017, 03:46 PM   #18
willbill642
CB7tuner Member
Would the lower control arm work from something like a Prelude or first gen TL? Don't those use the larger size balljoint? Or is it even bigger?
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
