I figured most of the DIY's Ive seen didn't have much pictures( If any) so I decide might be good time to update.
First put car on jack stands or lift.
Grab a 19MM socket and take off the lug nuts
Take off the tire and put it under the car
Grab a 36MM socket and very large breaker bar or impact gun. ( On mine the
nut was stuck, had to use a torch to heat it up)
Grab a 17MM, take the cotter pin out of the lower ball joint and remove the 17MM castle nut.
Use a pitman arm remover or grab a pry bar and carefully pry down on the lower control arm while a friend carefully hits the LCA to "break loose" the balljoint.
Grab the 17MM to take the caliper and pad cradle off, hang it up safely
If you want take the outer tierod if you want, I didn't
Take the 4 10MM 12 point bolts out.
Run to the hardware store and grab 4 10MMx1.25 bolts the longer the better.
Put the new bolts in where the 12 points were and hammer the shit out of them in a even pattern and the bearing will come out of the knuckle
Then take the 4 bolts that hold the rotor on off, then the Hub and Bearing will slip out of the rotor.
This is a good time to see if you need new bearings, rotate them they should be smooth, pull them they should not move side to side. If they are fine consider your self lucky you won't need to have new bearings pressed in.
do i go get it pressed out or beat the fuck out of it with my big ass hammer
